Installed: San Diego Off Road Solutions - Elripster: 1986-1995 IFS Ball Joint Spacers
Old Mar 8, 2004 | 05:58 PM
sschaefer3's Avatar
I ground the arms and installed them. Looks good and we really softened up the t-bars. The 92 Mini should be on par with the Frankensteins.
Check it out:
http://fastq.com/~sschaefer/san_dieg...olutions_.html
You can grind a very nice factory looking arc into the back of the arms with a 4.5" grinder and an abrasive disc.
Old Mar 8, 2004 | 06:02 PM
elripster's Avatar
Steve, thanks for the write up!!! Definitely look forward to seeing how you like them on the trail.
Frank.
Old Mar 8, 2004 | 06:08 PM
sschaefer3's Avatar
Frank.
The empty spot where pic #10 would go is for a trail shot. It should do well.
Old Mar 8, 2004 | 06:12 PM
Flygtenstein's Avatar
Moving into the old junk, eh?
I have been curious about torque specs on the stuff to crank it down. Did you just cinch them tight?
Did you take the upper arm all the way off to install and paint it? Looks almost new.
Old Mar 8, 2004 | 06:32 PM
sschaefer3's Avatar
We just lostened up the t-bars and un-bolted the upper ball joint. The key is not to let the arm hang down too far with everything undone, the tripod will pull out and then you gotta stick it back in. That only happens when it's all apart.
Vern said taking the upper arms completely off is a huge PITA. So no I repainted it right there on the truck.
You can actually push down on the front now.
Old Mar 8, 2004 | 06:33 PM
sschaefer3's Avatar
We just tightened everything up real good. The t-bars are almost all the way out. Nice and soft.
Old Mar 18, 2004 | 03:49 PM
86toyota's Avatar
I've been thinking of getting those but was still waiting for more feedback. Anybody else running these?
Old Mar 18, 2004 | 04:15 PM
Cebby's Avatar
Steve, thanks for the great info and pics. I have the spacers but won't be able to get them in for about a month or so. About how long did it take to install them start to finish - including disassembly and grinding/painting etc.
Old Mar 18, 2004 | 04:35 PM
sschaefer3's Avatar
A couple of hours. I took the 92 Mini out to Florence Junction to the "testing area" and but the t-bars thought the pace.
Much much much better, but the Frankenstein’s still have the edge. We took the t-bars down to the arms being completely level and the front being soft to the push. It did do amazing for an 86-95, but it's no 3rd Gen.
I have pics I'll post soon.
Old Mar 18, 2004 | 07:45 PM
sschaefer3's Avatar
1992 Toyota Mini Pickup 4WD - 4" Pro Comp IFS kit - Standard Issue Procomp front shocks - Ball Joint Spacers - Chevy 63" rear leafs with Rancho 5000 - Front & Rear ARB - Marlin 4.7 Gear.
1999 Toyota 4Runner 4WD - 2" Frankenstein Front - OME 891 & Cornbred 1" spacers - OME Rear Shocks - E-Locker and ARB - Marlin Ultimate.
Old Mar 18, 2004 | 07:47 PM
sschaefer3's Avatar
Both vehicles have the Exact same tires. Those are my old MT/R's on the Mini so you see they are EXACTLY the same tires.
krimsonone
Sep 13, 2024 09:33 AM
Sep 4, 2015 09:27 AM
coffey50
Jul 28, 2015 10:55 AM
Athansinis
Jul 27, 2015 08:38 AM
ksmudrunner99
Jul 21, 2015 05:33 AM
