installed my ball spacers
Old May 26, 2004 | 10:00 AM
GMJK86SR5's Avatar
HOw do I adjust the a arms back to stock height. Different tires and the spacer make the measurement fornt the fender absolete? Can I tell by the lower a-arms? Should they be float across the front of the truck or should they angle down some?
Old May 26, 2004 | 10:13 AM
mt_goat's Avatar
The measurement from the top of the rim to the fender will still be a good way to check (15 inches or less I believe) I like the cv axles to be slightly lower (about an inch) at the wheel ends. The pictures at the top of this thread are a good example of too much angle on the cv's.
Old May 26, 2004 | 10:18 AM
mt_goat's Avatar
Oh well! When I got them in ther mail, the bolts and nuts were on the note side so I assumed that the notch went up. I do not remember reading in the install instructions about the notch. If it is not there, you may want to add the info. If it is there then I missed it. I will flip them the next time I get into the front end. Mike
You might be able to just drill a new drain hole, rather than taking them off and flipping them.
Old May 27, 2004 | 06:56 AM
GMJK86SR5's Avatar
I was thinking about just drilling a small hole. What do you think Frank???
Old May 27, 2004 | 06:59 AM
  #25
GMJK86SR5's Avatar
Mt goat,
your axles are an inch lower at the wheels. Are you measurring the axles and not the other suspension stuff under there?
Also, does anyone make disconnects for the front sway bar?
Old May 27, 2004 | 08:25 AM
  #26
elripster's Avatar
I'm on the fence.. it's work to take that stuff apart but not that much work. Here's the thing, even if you put a hole in it, unless the hole is flush with the ball joint, some water can pool there. Whether there's .25" or 1" of water, water is water and it's the ball joint you have to worry about. It will be wet either way. If you drill too close to the joint, you could damage it... though you'd have plenty of warning. The other issue is accesability. I figure the wheels need to come off because you want the holefacing outwards (where the notch would have been) since that's the direction water will run. At that point you are darn close to just flipping them over. Add drilling time I'd say you are 2/3's of the way to flipping them.
I'd say play it safe and just flip 'em. Much of the initial work is the cutting. With that already done you should be able to disconnect the sway bar, pull the wheels, put something under the UCA, and flip 'em inless than an hour.
Frank
Old May 27, 2004 | 08:37 AM
  #27
mt_goat's Avatar
Mt goat,
The only thing I measure is from the ground to the fender rim and that's just to get it level. I just eye ball the cv angle, as you can see from this pic there isn't much angle on them http://community.webshots.com/photo/...46850258xPOAND I'm not saying you can't go with more angle than mine, especially if you have manual hubs, I'm just saying the pictures at the top of this thread are too much angle, even for just moderate 4 wheeling. You can also see my sway bar discos in the same pic, they were made by http://www.frontrangeoffroadfab.com/disconnects.htm They are quick to disconnect but not so fast to reconnect, still faster that unbolting and rebolting the stock one though.
Sep 4, 2015 09:27 AM
coffey50
Jul 28, 2015 10:55 AM
terminator
Jul 27, 2015 07:13 PM
msane99
Jul 27, 2015 06:14 PM
ksmudrunner99
Jul 21, 2015 05:33 AM
