Inner hub bearing
Old Jul 16, 2015 | 04:26 PM
glowz825's Avatar
Inner hub bearing
Hey,
I could really use some help. My inner hub bearing is shot. I pulled the steering knuckle and found the inner brass bushing. From what I have heard these are pressed in. My question is; how do you press out the bushing? And when said bushing is pressed out, will the inner bearing come out with it? The wheel bearing it self is fine.
Thanks
-Greg
Old Jul 16, 2015 | 11:57 PM
wyoming9's Avatar
Red face
You might want to let us know Just what your working on??
There are differences in the older and newer models
I am not sure just what your calling a bushing in the hub??
Again without the year I am clueless.
Old Jul 17, 2015 | 04:50 AM
glowz825's Avatar
Yeah, I guess that would be helpful LOL!
95.5 Tacoma
Single cab
5vzfe (not sure if the engine matters)
Manual locking Aisin hubs
This is located in the back side of the steering knuckle.
Old Jul 17, 2015 | 06:38 AM
Team420's Avatar
I thought the new models had wheel hub assemblies? Just replace the whole thing and be done with it. I havent done any front end work on 95.5 taco's tho, so I could be wrong.
Old Jul 17, 2015 | 12:28 PM
glowz825's Avatar
I know the 2nd gen tacos are configured this way. ORS sells the brass wheel bushing and the inner hub bearing. So I figured it has to be serviceable
Old Jan 25, 2022 | 09:28 AM
redsr5's Avatar
Smile Brass Bushings
You have to pull the brass bushing in order to get the roller bearing out. Pull brass bushing with a "Blind Hole Bearing Puller" . This tool is available at Harbor Freight Tools for around $40. Works like a charm! Good Luck!
G-off
Dec 29, 2015 12:44 PM
AaronM
12
Nov 4, 2015 04:06 PM
YotaPagota
Sep 20, 2015 06:24 PM
Adam Edgar
Sep 20, 2015 03:24 AM
sonorn67
Sep 19, 2015 05:39 PM
