Inclinometer is in
Old May 17, 2003 | 10:55 AM
Victor's Avatar
Inclinometer is in
I flip flopped on how to mount it on the dash but there was no easy way without a bracket on the bottom (no easy way that is). I mounted it to the front of my floor console angled up at close to 15 degrees. Let me know what you guys think.
Old May 17, 2003 | 11:19 AM
Victor's Avatar
And the view from the driver's seat.
Old May 17, 2003 | 11:52 AM
Mack's Avatar
Cool!
Hey it works, only problem is you have to look down to see it.
Old May 17, 2003 | 01:37 PM
Cebby's Avatar
He'll be looking down to check his pants when he's at 30 degrees, so looking down at it is OK...
Looks great Victor. What color was it when you got it?
Old May 17, 2003 | 03:19 PM
delboy's Avatar
Old May 17, 2003 | 03:40 PM
castrolSi's Avatar
Looks great. I snagged mine out of a junkyard.
~Wade
Old May 17, 2003 | 03:49 PM
Victor's Avatar
It was maroon or whatever they call that blood red.
Old May 17, 2003 | 07:04 PM
toyota parts dude's Avatar
victor that looks cool how you mounted it down there out of the way. hey i was just wondering how that blower motor relay worked for you did it fix your problem. did not hear you say anything on the forum.
Old May 18, 2003 | 07:46 AM
Victor's Avatar
Nope that wasn't it. I'll have to recheck al the wiring that goes to that relay and also the switch again although they all checked good the first time.
Old May 18, 2003 | 07:54 AM
TDiddy's Avatar
Classic!
Looks good Victor!
Old May 18, 2003 | 10:46 AM
aviator's Avatar
SWEET!
Looks good man! Now I know where I'll put mine when i get it> Aviator
Old May 18, 2003 | 01:39 PM
Victor's Avatar
I mounted mine to the plastic cover behind it. It had a shelf built in it but when you remove that plastic from behind you can see it uses 3 self tapping screws to hold the shelf on. I used those to hold the back cover of the inclinometer. I was able to measure it very carefully so that the 3 screws lined up and the bottom of the inclinometer is being supported by the shifter console.
Mine didn't come with the metal base so I think it is lighter and is supported well. It may not work so good with that metal base. I was going to use a piece of angle iron screwed into the bottom of the inclinometer and then screwed to the shifter console but this worked out better I think. I can remove the front of the inclinometer with 2 screws, I have quick electrical disconnects for the wiring. Because of this I was able to follow Roger Brown's directions to get the full movement of the gauges.
Old May 18, 2003 | 05:53 PM
tomus1000's Avatar
Looks good. What color is the illumination?
Old May 18, 2003 | 06:00 PM
Victor's Avatar
Its the same green that matches my dash.
Old May 18, 2003 | 08:32 PM
OicnaiC's Avatar
The 30 really isn't that steep.
Old May 18, 2003 | 09:01 PM
Hawaiian4R's Avatar
Lookin good.
Old Jul 25, 2006 | 04:37 PM
CDUFF7's Avatar
Lookin' Good!
ewong
May 2, 2018 04:03 PM
AkitaDog
Sep 1, 2015 08:05 AM
pattycakes77
26
Jan 15, 2008 06:55 AM
94dodgedakota
Jun 19, 2005 07:49 AM
rimpainter.com
7
Jun 16, 2003 08:54 AM
