Important Survey II, Please Respond
Old Feb 1, 2005 | 11:39 PM
Bigkahuna808's Avatar
1) 97 4runner
2) Easy, bumpy roads and minor sandy trails
3) Dent in rim (dont ask, but I sold them for cheap right after that), the sway bar bushings, poped a shock.
Old Feb 2, 2005 | 03:57 AM
Ilovemountains's Avatar
88 4x4..
My rig is an 88 4x4. I’ve wheeled on everything from gravel roads to trails where I thought for sure I was going to roll it back down! I’ve broke, 1 CV , 1 front shock, 2 stock skid plates “ time for a Bud Built” ripped a few side walls out of tires, ruined a stock rear bumper going down through a wash out, worn ball joints out to the point that I was amazed they were still holding together, exhaust systems, driving lights "I actually cracked one of my Hellas last week" I’m on my 3rd stock antenna, 1 rear window panel and my rear diff sounds TERRIBLE. That’s about all I can think of besides scrapes and dings on the body, oh and my front lower valance panel under my bumper has been pulled back out a few times!
Old Feb 2, 2005 | 06:04 AM
AznSky's Avatar
this is exactly what I needed guys. Keep em coming!!
And Thank You to the Mods for making this a sticky
Old Feb 2, 2005 | 10:22 AM
Steve 1stgen's Avatar
1) Toyota / 4Runner/ 1988/ 190k
2) Easy
3) Nothing broke, just rock scraps on undercarrage (I hope I am not jinking myself)
Old Feb 2, 2005 | 10:23 AM
  #25
SLC Punk's Avatar
1) Make/Model/Year/Mileage Of Your Rig
1997 Toyota 4Runner 89,000 miles
2) Type of Trails You Drive (Easy, Moderate, Difficult)
Easy
3) Name anything and everything that you've broken and how you broke it.
Nothing yet!
Before the 4Runner:
1994 Ford Ranger XLT-Extended cab 90,000 miles
Moderate
Crushed rocker panel, scratches, broken plastic front bumper valance, blew out 2 firestone radial ATX on separate occasions.
Old Feb 2, 2005 | 10:27 AM
  #26
Jeffires's Avatar
1. 91 4wd 175k miles
2. Easy to Moderate (Louisiana highways are moderate)
3. CV joints, several idler arms, dents and scratches
Old Feb 2, 2005 | 11:02 AM
  #27
99runner4me's Avatar
1. '99 4R 2wd(gets taken-out more offroading), 60k mi, '97 LC, 4wd, 115k mi.
2. Easy - Moderate. Mostly backcountry adventure trails.
3. Nothing broken yet.
Old Feb 2, 2005 | 01:58 PM
  #28
colsoncj's Avatar
87 4Runner 221K, mods in signature
Moderate to difficult
Only damage was light body damage, Ripped off the front valance and license plate, and dented the rear bumper pretty good
Old Feb 2, 2005 | 04:50 PM
  #29
Darx's Avatar
1) Toyota/Tacoma/2001/94,200
2) Easy, Moderate, Difficult
3) Passenger rear fender flare due to rubbing during articulation. CB antenna mount due to excessive rocking motion from crossing rock garden. Crushed exhaust opening from departure angle on large rock. MAF sensor from excessive dirt passing air filter. All four mud flaps due to rubbing during articulation. Pinstriped paint job due to brush along side of trails.
Nothing major really.
Old Feb 2, 2005 | 08:38 PM
  #30
AUJWE
Guest
Posts: n/a
Toyota/4Runner SR5/2000/56,600
Easy
Just dents from brushguard
Old Feb 2, 2005 | 09:57 PM
  #31
hamstrungtaco's Avatar
i busted a fender and tore off the flare, hammered it back out good as new, skid plate issues as well
Old Feb 2, 2005 | 09:59 PM
  #32
uboatcmndr's Avatar
2000 Toyota 4Runner SR5. 39,0000 miles. Trails around hear have about 2' diameter rocks. I have'nt broke anything but my body damage from tight areas (trees) are extensive. Lower A arms are raked to Toledo and so is my stock front skid plate and my stock rims have grind marks as well as my front stock bumper is toast sans lower plastic valence. Along with my stock antenna listening to the AM in the hollers.
Old Feb 3, 2005 | 04:20 AM
  #33
4mydogs's Avatar
1. Toyota 4Runner, 1995, 136K.
2. Easy.
3. Nothing so far!
Old Feb 3, 2005 | 05:47 AM
  #34
Flygtenstein's Avatar
1. 1995 4-Runner
2. 9/10 in Colorado, 4.5/5 in Utah, and 4.5/5 in Arizona, Mud in Wisconsin
3. Busted:
-CV's
-Idler Arms
-Pitman Arm
-Tie Rods
-Rear Driveshaft
The concept of "difficult" should be normed for this discussion. One locker and 31's does not run "difficult" trails.
Old Feb 3, 2005 | 05:58 AM
  #35
MudMonkey's Avatar
1996 Taco 155,000 miles
Easy to Moderate
Rear Diff
Old Feb 3, 2005 | 07:51 AM
  #36
dlbrunner's Avatar
95 4runner, 53,000 Mi
Heavy moderate, maybe light difficult
Dad munched an idler arm.
I think something is wrong with the front end now, funny noise when hitting some bumps, I think the front shock is bad, not sure yet.
On the old trucks: Exploder: Several flats, tons of pinstripe, launched 30 feet over a culvert, set on its side and spun around, both bumpers bent from approach depart angles. Cruiser: munched a corner, and set it on it's side (deep snow, very little damage woohoo). 89 p/u: Trashed skid plate, pinstripe, ruined idler arm, almost lost a wheel once from loose lug nuts.
Notes: All the toyotas have seemed to hold up much better off road, but I really tried to destroy the Exploder and put it through hell. All vehicles have been stuck a few times, and been places that resulted in positive failure ie: could not continue on trails or had to be pulled thru.
Old Feb 3, 2005 | 12:18 PM
  #37
ETN4runner's Avatar
1985 4runner efi, 145xxx miles
Moderate Trails
Old Feb 3, 2005 | 02:44 PM
  #38
deathrunner's Avatar
1. 1989 4runner 22RE 5Spd with Long Travel IFS
2. Moderate
3. Dented the rear tin bumper on a rock
Ripped Cv boot (Travel wasn't limited)
Aisin Hubs
Bolts on exhaust pipe near header flange exploded in water crossing
Worn Idler arm bushings
Two Ball Joints
Losts of pinstripes
Old Feb 3, 2005 | 04:17 PM
  #39
kryptik's Avatar
1) 94 Toyota Pickup 96,000 miles.
2) I've only been on easy trails as of yet. Mainly becuase I just got my truck and have only been out in it a few times.
Old Feb 4, 2005 | 07:08 AM
  #40
Silver_Truck's Avatar
1) 91 truck ext cab V6 SR5, 395,500 miles
2) Easy and moderate
3) Scratches, couple dents, bent and broken exhaust pipe, creased skid plate. Nothin serious...yet
