I'll never own another toyota
Old Feb 22, 2008 | 12:32 PM
  #61
cackalak han's Avatar
Originally Posted by icerunner
Kia is SOUTH KOREAN and South Korea IS a Democracy and has been since the Korean War....Remember they our our allies
Looks like someone slept during their history class.
Old Feb 22, 2008 | 01:52 PM
  #62
'884Runner's Avatar
Engine design and care IS important.
yet I was trying to compaire APPLES to APPLES....
Let me spell it out what I was trying to say:
1) 4 cyl engines typically have to RPM higher on a consistant basis and work harder to push the the SAME vehicle WEIGHT....What does this mean? Due to the INCREASED REVOLUTIONS (or RPM's) over time ...the engine is simply worn out quicker(pistons, cylinder walls, valves bearings injectors ect)....This is the bottom line why engines with fewer cylinders will wear out quicker. For a given miliage...... 8 cylinder engine is better than 6 cylinder engine, and V6 is better than 4 cylinder engine.
it a known fact that a 4 cyl engine with 200K miles will have significantly more wear than a 6CYL engine with 200K miles . Of coarse given the fact that they were driven excactly the same and engines are of similar design.
Im not saying there are not some reliable 4cyl engines out there because there is of coarse......example the 22r/22re a great freaking engine... YET, if they made a similarly desgined 6 cyl, the 6cyl engine should last longer if placed in the same vehicle model.
Again all things being equal other than engine size, a 4cyl has to work harder to push the same weight than a 6 cyl engine...
there fore the engine will infact wear out quicker than its v6 counterpart.
Come on now, this is common knowlegde that has been known for over 50 years ....and you call it a "LOAD" ....?
Now an opposing view to this and if we want to split hairs even further one COULD say that because a larger engine has more parts (injectors, pistons valves, bearings ect) there is a increased chance for one of the parts to be defective thus causing an engine failure...?
Maybe that arguement could be made?
YET, at the end of the day, an engine that has seen a Billion revoulutions will have more wear than and engine with only 3/4 of a billion revoulutions.
over and out
That's a 50 year old theory using 50 year old information. This was before most domestic car producers learned how to build a decent 4 cylinder. I would think that an inline engine would be more reliable due to the longer stroke and less balancing required. Most 6 cylinder and 8 cylinder engines use a V construction. Also, it would depend on how you drove the vehicle and the load put on the engine.
Old Feb 22, 2008 | 02:34 PM
  #63
Whitey13's Avatar
Originally Posted by ozziesironmanoffroad
id rather have a chrysler than a kia, at least id be keepin the money in america, and not sending it to the commies. sorry, but i was raised anti commie. i refuse to drive kias period. one comes in at work, i tell someone else to drive it in, and drive it out, i wont drive it.
A month before Chrysler was aquired by Cerberus, last summer, they (Chrysler) signed a deal with one of their partners in China to sells Chinese manufactured cars in the U.S.
The whole "keeping the money in the U.S." point is moot when all of us here drive Japanese trucks. At some point, someone bought our trucks and put money directly into Eiji Toyoda's pocket.
Old Feb 22, 2008 | 03:10 PM
  #64
racingcameron66's Avatar
i also have a 1998 taco 2.7 and this is the probs ive had with it:
1) coal packs
2)...
3)...
4)yea thats it
Old Jun 2, 2008 | 10:09 AM
  #65
NaeSLaS's Avatar
just a thought, maybe a dying slave cylinder caused the clutch to not fully disengage and wear out after 90k miles?
Old Jun 2, 2008 | 10:40 AM
  #66
X-AWDriver's Avatar
As far as trucks go I don't think I'd own anything outside of a Toyota;I've now got almost 140k on mine and the only thing that doesn't work is the power antenna (which quit about 8k miles ago) and I replaced the axle seals at 100k otherwise it's just been regular maintenance and just did the timing belt,water pump and a few other services just last week.
And got it dirty and a bit tippy just yesterday.
Old Jun 2, 2008 | 10:49 AM
  #67
DeathCougar's Avatar
1) coal packs
2)...
3)...
4)yea thats it
Your tacoma runs on Coal?
Old Jun 2, 2008 | 11:05 AM
  #68
1stgen4gunner's Avatar
I swear dude invest in a 3.4, they are ultra reliable (not that the other engines arent) and it will feel like a new truck.
Old Sep 4, 2010 | 07:21 AM
  #69
Red3.slow's Avatar
I fear this is becoming a more common trend I know two people who purchased and 05 and 06 tacoma new. The 05 went though a transmission in a little less than 500 miles and the 06 had a cab leak that was never solved. I will say the 05 had a new trans installed under warrantee and I've never heard my friend complain about it since, he love's in infact.
Old Sep 4, 2010 | 10:55 AM
  #70
evolve23's Avatar
The toyotas i've owned have been the best vicles i've had.
Old Sep 4, 2010 | 11:47 AM
  #71
MortonPhotographic's Avatar
Tell the mechanics to change out the fuel filter. I am no expert, but your problem sounds oddly like one I had with a '78 pu and 22r. I could do 65mph on the freeway, but at 66mph it would shake, shutter and go crazy. Anything back down below 65 was fine. Turns out the fuel filter was plugged with rust and that starved the carb for fuel.
Colington
Mar 8, 2020 09:51 AM
Sep 4, 2015 09:27 AM
crashburnoveride
Aug 28, 2015 09:20 PM
nick b
Jul 11, 2015 04:38 AM
