Ignitor failure?
I'm voting for a bad ECU even though you had it checked. I went through this with a V6 Camry, I also forgot to disconnect the battery and to make it worse my buddy left the ignition on while I was working on it, until I heard something clicking. Got another igniter and it ran for a few weeks and then died, another one lasted a couple months. After testing and double checking everything I got another ECU from Ebay...runs like a charm and I have no idea why that ECU kept taking out the igniters...
D
D
#26
The coils share a power supply with the igniter. Should be black wire with red tracer. Should all have 12v in the run position. I believe the igniter provides the ground. And the igniter is grounded on the intake manifold above the oil cap. No spark from only one coil and its not the coil sounds like maybe a wiring issue. Computers and igniters very rarely fail. Have you re-checked for trouble codes?
#28
#29
ecu compatibility
Looks like I may have found a compatible used ECU. There is a slight difference on the numbers on mine vs the one for sale. Mine is pictured. The one I am considering buying has the last digit of this line different:
175000-90020 mine
175000-90010 seller's
Everything else matches. The part number on both is 89661-3D310. I am hoping that I can use this computer plug and play. Anybody know for certain?
175000-90020 mine
#33
Maybe it does as well, don't know. But it definitely has an external ground wire that bolts to the intake and they wont run without it. I've had trucks towed in after someone did spark plugs and forgot to tighten the ground
#34
I don't have the motor you have, but it just seems weird that an ECU would fail after a timing belt replacement. I 'am aware you left battery connected during repair, but did you check any and all fuses, links or possibly something not plugged in. Just wondering as I'd hate to see you put in an ECU for nothing. Man, I hope you find what it is.
#35
I'm thinking it would also be possible to hook the hoses up wrong to the IAC. I've never seen anyone admit to that though.
#37
after a few attempts to crank, she started and idled very roughly for about 10 seconds or so at ~1300 rmp. Threw a code, p0340 camshaft position sensor. I removed and meticulously cleaned the camshaft sensor, the code quit showing up.
Now back to starting for a second or so, then dieing immediately. No error codes presenting.
#39
Still stuck here. She starts for a second, then dies. I have ruled out the following:
ECU
Igniter
Cam sensor
crank sensor
coil packs
wiring shorts between all the above
timing belt/pulleys are all installed appropriately.
I am not getting a check engine light.
Any thoughts, suggestions? I terribly frustrated and out of ideas. Nearly a month now without my 4runner, I miss her.
ECU
Igniter
Cam sensor
crank sensor
coil packs
#40
Vacuum leak like was suggested above? I would run a boost leak test and see if you can spot any leaks. If you have a big enough leak it will act like the MAF sensor is disconnected and do what you are seeing.
Ebay ECU next I guess?
