Ignition Wire for 03 4runner
Old Dec 31, 2004 | 09:14 AM
timber725's Avatar
Hi all,
I need help identifying an ignition wire for the 03 4runner. I want to tap into the wire so that I can turn on aux lights only when the ignition key is in.
Please help me with the location and color.
Thanks
Loi
Old Dec 31, 2004 | 09:18 AM
Good Times's Avatar
Loi, check your fuse located in the dash to the left of your steering column. Just use a test light to find an acc tab and tap in from there. Make sure you use a relay and just the tapped acc tab as the trigger signal and then have the power come from the battery directly into the relay to the aux light.
There should be atleast 1 acc tab available as I'm currently using it for something as well.
Good luck
Old Dec 31, 2004 | 09:23 AM
timber725's Avatar
Good Times,
Looks like you have nothing better to do on New Years Eve, too.
You know the color?u
Old Dec 31, 2004 | 10:06 AM
Good Times's Avatar
not sure off hand as the truck is sitting out in the rain. plus i'm at work today of all days so life is abit grim. lol
just use a test light and find an open fuse section. it's all trial and error. you won't break anything so no worries.
toyotamonster
3.4 Swaps
7
Apr 16, 2020 06:02 PM
Jdgarrison
Oct 1, 2015 05:22 PM
msane99
Jul 11, 2015 08:08 PM
toyota32
Jul 6, 2015 05:42 PM
colinmil
Jul 6, 2015 04:03 PM
