Ignition "locked" while trying to start
Old Nov 18, 2006 | 05:57 AM
waskillywabbit's Avatar
Originally Posted by rocket
Thats exactly what i did when i had the same problem that got continuously worse....so bad that it sometimes took many attempts to turn the ignition and/or pull the key out. So i bought and squirted a $3~ tube of dry graphite lubricant into the cylinder and at the same time, i got new keys (dealership) that were computerized cut via my VIN number. Bingo! Problem has been solved for 3+ months now. That dry lube was key...pun intended.
x3
I wouldn't trust someone at Walmart to cut me out of a paper bag, much less a key to my ignition. :pat: Pay the extra $$$ and get one cut off the VIN at the dealer and use the graphite.
I have seen several vehicles that had "discount" places cut keys for the ignition, one Honda in particular, and the owner had to wind up changing out the whole ignition cylinder cause he was too cheap to pay up for a proper key.
Old Nov 18, 2006 | 09:11 AM
Swede's Avatar
After looking carefuly at my keys, I've noticed that the shank is a bit twisted compared to the handle part. I twisted it back so that it lines up with the handle and haven't had a problem since! Hopefully this cures it.
Old Nov 21, 2006 | 07:26 PM
Machine's Avatar
Had the same problem sometimes 20 mins to get it to start... I was all about finesse if you softly turned it and pulled up it would catch and crank... I got sick of FINESSE so I spray some dupont teflon in there and It has seem to fix the problem for the time being... If it does it again I'm rewiring the ignition system to run off a keypad system and just use a code to crank it!
Old Nov 21, 2006 | 08:06 PM
YotaFun's Avatar
I'l put in my .02
I had this problem and ended up getting a new key cause
1) mine was warn...
2) the top platics part butsted...
Good thing I also had the little tag with the numbers so they could make the key nice and fresh at the stealership...
Good thing I had the valet in the glove box at the time...
I got my key out, put the valet in and it worked just fine...
The only time I have a problem now is if I have the wheel turned ever so slightly or I parked it turned twaords a curve (when I have to park on the street at school)
I hope you get your problem fixed...
That sounds really iffy...
I would have gone mad by now...
(to the point i might have actaulyl broken off the steering wheel...)
Good luck....
Old Nov 21, 2006 | 08:08 PM
  #25
CJM's Avatar
CJM
Did ya check the starter? A friend of minehad this exact problem in his taurass and bingo starter was no good.
Old Nov 22, 2006 | 12:49 AM
  #26
rocket's Avatar
Did ya read the thread? lol This isn't about a "starting" problem. It's about putting the key in and it simply wont turn. I.E. ignition/cylinder stuck in the off position.
It's most likely one or two things...worn/crappy made keys and/or a lack of some good ol' lube. Use graphite.
MO transplant
Apr 23, 2023 11:58 AM
sandyota
Feb 4, 2021 11:16 AM
toyotamonster
3.4 Swaps
7
Apr 16, 2020 06:02 PM
msane99
Jul 11, 2015 08:08 PM
colinmil
Jul 6, 2015 04:03 PM
