IFS travel measurements and pics
Old Dec 29, 2003 | 01:52 PM
RTdawgs's Avatar
setup tested:
- SAW coilovers
- ATS upper control arms
- Revtek 3/8" topout spacer
- swaybar disconnected
on level ground i sit at 15" from top of wheel to bottom of LTD fender, i also have a 1" body lift.
at this pic, all the weight is at the rear of the vehicle, so i feel another 0.5" - 1.0" of uptravel ("stuff") could be accomplished if more weight was added to the front. however, when i went through the obstacle nose first, i was too nervous to get out of my vehicle and measure the travel since my drivers side rear tire was 2' off the ground
the drivers side is stuffed the bumpstop and the passenger side extends just enough so that the balljoint barely contacts the spring (as circled in the pics).
the passenger side front tire is off the ground
now for the measurements:
Drivers side: 9" (top of wheel to bottom of fender)
Passenger side: 18.5" ( " " )
(i also have measurements from center of hub, but i feel those are more arbitrary to be standardized)
so thats 9.5" of travel with all the weight on the back tires
just thought i'd share my recent findings with the public. the revtek spacer added additional downtravel to the suspension, but i also feel that it might have limited the compression of it as well. i think i remember my previous testing (without the revtek spacer) to be in the 8" range on the compressed side.
i am thinking that the Revtek spacer increased the downtravel just as much as it decreased the compression.
is this good or bad, i guess it depends on the situation.
Old Dec 29, 2003 | 05:15 PM
ravencr's Avatar
My pics are here: http://www.toyota-4runners.com/windrock12-27-03.html and my measurements were 8.5"-9" of travel.
Chris
Old Dec 30, 2003 | 03:56 PM
RTdawgs's Avatar
Chris
cool pics, wish i couldve made it, hopefully next time.
delmert
Sep 30, 2015 04:34 PM
SMOD
Jul 27, 2015 01:45 PM
TURBOrunnerNM
Jul 20, 2015 08:31 AM
scottyg486
Jul 19, 2015 05:34 PM
94whiterunner
Jul 12, 2015 07:15 PM
