IFS diffs Suck big time
Old Dec 31, 2003 | 06:25 PM
Hyperlite's Avatar
Question IFS diffs Suck big time
My front diff is making clicking sounds after 300 miles. I drained it to find alot of metal shavings. It pulls to the left in 4wd, passenger tire barks and makes a loud "CLUNK" when disengaging. It is a new diff from Randy's Rack and Pinion. Could this be a problem with ADD or the intermedate shaft. My Drive axle and CVs are fine.
Does anyone know what this is befor I tear it apart again
If my Bronco worked I would part out my runner and send it to the scrap yard
Old Dec 31, 2003 | 07:15 PM
Waterboy's Avatar
Sounds like the gears were set up bad or not broken in right. Did you upgrade to smaller (I think that's what you call higher numbers) gears?
Old Dec 31, 2003 | 08:18 PM
Cebby's Avatar
Wasn't Randy's the place that Keisur had problems with? Sorry to hear about the problems. I vote bad setup IMO.
Old Dec 31, 2003 | 09:03 PM
amusement's Avatar
There are two reponses to Randy's ring and pinon in the Yota vendor customer feed back section ...
#1 #2
Old Dec 31, 2003 | 09:27 PM
Hyperlite's Avatar
Should have listened to Keisur............cause I am story #1
:pat:
It was 4.11 gears for the front and I had 4.10 from the factory. This front diff was built completly by Randy's. Hope it's not his fault and it is the ADD cause I don't want to rant another thread in vendor customer feed back
:cry:
lledwod
Aug 30, 2016 01:03 PM
msane99
Jul 11, 2015 08:08 PM
colinmil
Jul 6, 2015 04:03 PM
ptb12
Jul 5, 2015 01:49 PM
