idea for mod
Old Sep 6, 2002 | 02:11 PM
CLin9383's Avatar
idea for mod
does anyone know if you can move the cup holders down to where the 99's have them and also does anyone know if i can get the instrument panels like the 99's to fit in the 96?? thanks!
Old Sep 6, 2002 | 03:32 PM
Bob_98SR5's Avatar
Clin:
I was pondering this same question and looked at it quite seriously b/c I have both a 99 and 98 in my possession (until Monday). I know EXACTLY what you're thinking of doing. While I'm not sure it can't be done, there are a few things I discovered that would make it very difficult.
First, the e-brake is offset to the right in the 99 whereas the 98 is centered.
Second, the placement of the A/C vents would prevent you from utilizing the 99.
Third and I'm guessing here...I can almost bet you that the 99 uses different relays.
Now, I think you might be able to work the center arm rest thing and the cupholder provided you can unbolt the e-brake and off set it to the right. The center console IMHO, is not worth the effort.
Good luck!
Bob
Old Sep 6, 2002 | 03:55 PM
CLin9383's Avatar
interesting....i'l check with toyota and see if they know anything about it!! thanks tho bob!
malteserunner
Early Land Cruisers (Build-Up Section)
89
Feb 9, 2018 06:59 AM
Bawlzdeep
Aug 2, 2015 08:35 PM
Massmayhem247
Jul 18, 2015 05:46 AM
icentropy
Jul 11, 2015 07:21 AM
Nickdigg
Jul 7, 2015 06:04 AM
