I want a Optima but ...
Old Mar 8, 2005 | 08:20 PM
van7559's Avatar
Does Optima make an aplication for my rig 94 w/22re
I went to their website, and did the search for my pickup, which is a 94 2.4 22re, and it said that there were no applications found. I know somebody here runs an optima in their pickup. If somebody could give me the part number or the specs of the battery I need, I would appriciate it.
Old Mar 8, 2005 | 08:37 PM
4rnr's Avatar
As far as I know an optima is an optima. There is a red top (designed for high reving quick discharges for race cars) Yellow top (designed for high amp loads like winch and big stereos this the battery you want) and the blue top wich is a marine battery. Some 4wheeling guys run red tops because they are a little cheaper and thats fine. But I have a Yellow and I have run 6 hellas and a huge stereo (very loud) for about 7 hours one night at a party, and my truck started up no problem. While my buddy has a redtop and his is strong but not as strong. I would just go to an optima dealer and ask for a yellow top. It should cost about 170-180, but some places like pep boys sell cheaper ones they sell refurbished ones ( they told us they didnt, liars) and the red top we bought from them was a pile of crap. I got my yellow from circuit city.
Old Mar 8, 2005 | 09:42 PM
ChickenLover's Avatar
The yellow and blue tops are deep cycle batteries. They are made to be drained and recharged. The red top has more power (cold cranking amps and cranking amps). There are several different models of red tops. I personally use the 800u dual terminal. It is the most powerfull of thier lineup - to the best of my knowledge. I needed to use an optima spacer (free from optima) for a proper fit in my runner. I would imagine the 800u would fit in your 94 just fine with the spacer.
Old Mar 8, 2005 | 10:21 PM
jimbo74's Avatar
the 34r is the one you need... find a place that sells them... the site isnt accurate.....
you will need to extend one of the batter ycables though i think
Old Mar 8, 2005 | 11:30 PM
humanoid's Avatar
This may be what you're looking for. Says orange top, but really is a red top, go figure.
http://www.tna-sports.com/index.cfm?...9651&product=8
Old Mar 9, 2005 | 05:50 AM
EnolaGaia's Avatar
I'm not sure about the OEM battery group / size on your '94. On Tacos ('95.5+) it's a group 24R (group 24 with reversed terminals). If yours is a 24R like a Taco, the best Red Top fit is a 34R + about 1" to 1.5" of spacing using either a home-fabbed spacer or an Optima 'adapter'.
If you go back to the Optima website, they **do** have a specs page that gives the physical dimensions of all their models. You can use that data to figure out which Optima best approximates your OEM battery sizing.
Old Mar 9, 2005 | 06:02 AM
4rnr's Avatar
WTF I just bought a battery and threw it in.
Old Mar 9, 2005 | 06:22 AM
lee's Avatar
lee
ok im about to buy one... can someone with a 3rd gen 3.4 WHO HAS ONE INSTALLED please tell me what i need to make sure it fits and everything, if i need anything at all that is...
Old Mar 9, 2005 | 06:39 AM
xcmountain80's Avatar
Yeah I have a pre 95.5 with a optima yellow fits fine just save the packing tray it comes with so that you can use it to properly space the battery in the toy's battery frame.
Aaron
Old Mar 9, 2005 | 07:16 AM
INsr5runner's Avatar
This is something that is pretty crazy. if you have read the tons of past posts on optima, it seems that everyone with a 3rd Gen had different problems. some needed a spacer, some didn't, some had to extend the cables, some didn't, and a whole combination of those. I think you should just get the spacer that is supposed to come with it (that many didn't get, but some did) just to be safe, and be prepared to extend your battery cables.
The Optima battery in a 3rd gen seems to have a different fit every time!
Old Mar 9, 2005 | 07:18 AM
Sparman's Avatar
34R with the spacer from Optima. This will fit without any modifications (i.e. hold down, cables, etc.).
Old Mar 9, 2005 | 07:19 AM
mt_goat's Avatar
You can adjust the height on your own by cutting plywood to fit under it, then use a sheet of rubber under it to keep it from sliding around. Just make sure the one you get has the terminals +- on the correct side for your truck. I like the blue top because it is deep cycle and has two extra wing nut posts on top for extra goodies. Also the blue has a longer warranty than the yellow for some reason, not that you will likely use the warranty.
Old Mar 9, 2005 | 07:26 AM
lee's Avatar
lee
thanks guys.
where do i get the spacer from? i'm planning on getting the optima from a local autozone type place that has much better prices than autozone... will they have it?
im sure they do, but thought i'd ask for the sake of asking..
Old Mar 9, 2005 | 07:49 AM
humanoid's Avatar
thanks guys.
Lee, I think you can get it directly from the Optima site... at least that's what I've heard.
Old Mar 9, 2005 | 08:38 AM
Sparman's Avatar
Lee,
I ordered my 34R from these guys:
http://www.1st-optima-batteries.com/red_top_battery.asp
as I couldn't find the 34R locally.
Call Optima customer service and tell them that you just ordered a 34R and will need the bottom spacer. They'll send it out no charge.
Old Mar 9, 2005 | 08:52 AM
lee's Avatar
lee
awesome, thanks very much.
Old Mar 9, 2005 | 10:36 AM
SEAN_at_TLT's Avatar
BINGO!
I have the old standard red top and I had to make some spacers and reroute my lines to make it work because the terminals were opposite of my OEM battery. The 34R or so called "orange top" with the included plastic spacer will drop right in no worries...
Old Mar 9, 2005 | 10:42 AM
PoBoy's Avatar
Buy at Costco...comes with spacer.
Old Mar 9, 2005 | 11:10 AM
mt_goat's Avatar
Originally Posted by SEAN_at_TLT
BINGO!
Which one of your many Toyotas was that in? Was the battery on the driver's or pass side?
Old Mar 9, 2005 | 11:25 AM
lee's Avatar
lee
sweet, need to go there after work anyhow...
