I want bigger tires!
Old Dec 10, 2004 | 03:21 PM
Yochdog's Avatar
ok guys....here is a picture of my runner as it currently looks. She is a 98, 90,000 miles, OME 2 inch lift all around, and an assorted array of other mods.
I was looking at one of the members 4runner on here that has 35 inch tires with Sequoia rims. It looks mean, and I think mine would look totally bad ass with the 35's. My question: Do I have to do any additional mods to make sure that 35's will fit? Thank you in advance for any help, I greatly appreciate it.
Old Dec 10, 2004 | 03:25 PM
User 051420's Avatar
http://fastq.com/~sschaefer/thirtyfive.html
That should help a LOT..The guy with the Sequoia rims is "HOJU", he's running 1.25" wheel spacers also.
Old Dec 10, 2004 | 05:22 PM
Yochdog's Avatar
the article is about running 315's. I currently am using 265's, is it possible to move up to 285's without as extensive a modification? I dont know if I really want to change out gears, replace A-arms, and start grinding down pieces of the runner. If anyone is using 285's on their runners, i would love some help.
Thanks a lot guys
Old Dec 10, 2004 | 05:30 PM
I have 285's and a 2" Body lift. They fit perfectly without rubbing. You can do the same with a 1" body lift.
Old Dec 10, 2004 | 05:47 PM
HOJU's Avatar
which OME coils are you using?
Old Dec 10, 2004 | 05:48 PM
Yochdog's Avatar
I am using the middle of the road.....i did not get the Heavy duty because I was afraid they might be too harsh. I still got at least 2 inches in the rear though.
Old Dec 10, 2004 | 05:51 PM
HOJU's Avatar
well with 2" lift you should be able to fit 285's, and if there is a concern for a little bit of extra room for insurance, then try some cornfed spacers... that should do the trick
Old Dec 10, 2004 | 06:26 PM
4Peanut's Avatar
Check my signature. Rubbing a little on the fender liner near the pinch weld.
Sep 4, 2015 09:27 AM
Dakotaneu
Aug 15, 2015 07:24 AM
94ofCanada
Aug 14, 2015 06:37 AM
nickbeauregard
12
Aug 7, 2015 06:04 AM
Michael oaks
Jul 27, 2015 11:47 AM
