I tried to change my fuel filter today
Old May 30, 2003 | 05:08 PM
Victor's Avatar
Well i depressurized the system and got less than a cup of fuel out of the inlet side - but then I couldn't get the outlet side nut to budge. Between the transmission crossmember, torsion bar, transfer case, and frame I couldn't move the 14mm more than a hair and guess what - that is exactly how much slack the fuel line has. End result - no movement of that nut. Well I'll probably pay the stealership for this one. I kick myself over and over thinking about how easy it would have been when the tranny was out for the clutch change
I always just drop BG44K in the tank and notice good improvements so I just did that instead today. I also replaced my radiator hoses, coolant, and belts today but I'll return the fuel filter in the mean time and get a new radiator cap - might as well since everything else is in great shape.
Old May 31, 2003 | 03:35 AM
Bumpin' Yota's Avatar
Did you try some form of penetrating oil? I had to use liquid wrench to free up the outlet nut.
Steve
Old May 31, 2003 | 04:32 AM
gwhayduke's Avatar
Doesn't it just pi$$ you off that you can do the hard stuff like swapping out your clutch, but you can't change a dogone fuel filter?
Old May 31, 2003 | 09:40 AM
Victor's Avatar
It will definatley make your crazy. The BG44k looks like its doing its thing very well. I have to run a lot errands today so we'll see how the truck is running by the end of the day.
Old May 31, 2003 | 09:44 AM
gwhayduke's Avatar
Trust me...if the filter hasn't been changed in a while, change it. I had mine done last summer and it helped the power and that gas mileage. Take it to Schlep Boy's or even the dealer. It'll cost you a $100 but you won't have to worry about it clogging up on your way to the Northwest.
smthwsn357
May 1, 2024 07:28 AM
Eggslinger
Jun 8, 2019 03:32 PM
Doug4320
Mar 24, 2018 10:11 PM
nick b
Jul 11, 2015 04:38 AM
Kluch8651
Jul 9, 2015 10:39 AM
