I need a tool
Old May 10, 2006 | 11:18 PM
kmchby76's Avatar
Originally Posted by SpikeStrip
Use an SST to compress the tensioner idler:
Here's where to get one:
http://www.etoolcart.com/index.asp?P...ROD&ProdID=110
It's worth the 40 bux. Save you hours and lots of @!%$&*!!
Found it cheaper: Same tool too.
http://www.sjdiscounttools.com/sch97300.html
Good luck.
found one on ebay, worked great. thanks for the help. i was successful. not bad for my first time, however i'm not too sure i got the crank bolt back on as tight as recommended.
Originally Posted by bigacuralvr
ok, so you can get the bolt OFF the starter way, but how do you torque that to 212ft/lb?? Thats my question. I fabbed up a piece of steel, with 2 bolts and a center hole...Worked perfectly!!
any chance you'll make another one? if so, how much would you charge?
Old May 11, 2006 | 04:09 AM
MTL_4runner's Avatar
Make absolutely sure you got that back on tight enough because you can seriously damage the crankshaft if it comes loose during engine operation.
Old May 11, 2006 | 06:28 PM
kmchby76's Avatar
what did you use to torque it down to 215ft/lbs? my wrench only goes to 150ft/lbs?
Old May 11, 2006 | 06:33 PM
GSGALLANT's Avatar
Either borrow/rent a larger torque wrench, or borrow/rent a torque multiplier to use with your torque wrench from someplace.
Old May 12, 2006 | 01:27 PM
  #25
bigacuralvr's Avatar
Well, it took me an hour or so to make that piece...so I'll have to see if I can round it up (we're in the process of moving). I bought the big daddy torque wrench at sears. It was like $150, or so...but well worth the extra money!!
Brett
Old May 12, 2006 | 01:39 PM
  #26
snap-on's Avatar
more to the point make shure you get the crank pully seated on the keyway right else you wind up with this
https://www.yotatech.com/forums/f116/lesson-learned-pics-76293/
Old May 15, 2006 | 07:31 PM
  #27
kmchby76's Avatar
well i managed to get it on to spec. she runs great.
jb451
7
Oct 7, 2022 06:58 AM
RobotMoose
Feb 22, 2020 07:44 AM
Scottcrb
Mar 3, 2016 11:57 AM
fabing455
Sep 7, 2015 08:08 AM
