I need a pinout for the 3.4 ecu 1996 4runner
Old 11-07-2009, 08:39 AM
cbrwags's Avatar
I have a 1996 4runner engine with automatic ecu 3.4 I have a few diagrams but nothing I can use. I need to hookup the body harness to the ecu for a engine swap.
Old 11-07-2009, 08:44 AM
eddieleephd's Avatar
some thing like this??
http://www.ncttora.com/fsm/2000/Repa...ine/terecm.pdf
to help more we need more info on what you need!
Old 11-07-2009, 11:05 AM
cbrwags's Avatar
I need a diagram of the wiring out of the ecu from the plug I dont have a body harness which is the 4th plug on the ecu so I will be soldering or plugging wires to the ecu.
Old 11-07-2009, 12:49 PM
cbrwags's Avatar
Thats it... Thanks. I couldn't open earler.
Old 11-07-2009, 03:33 PM
that is for a 98
Old 11-07-2009, 03:36 PM
Glad I could help you will need to go to
http://www.ncttora.com/fsm/1996/SIL/...bdb/terecu.pdf
this is for your truck found
http://www.ncttora.com/fsm/1996/SIL/fsm/repair.html
Old 11-08-2009, 09:08 AM
cbrwags's Avatar
I think the 98 one will work. The other ones you gave me must be for a manual transmission I have a auto ecu so the plugs are different.
Old 11-09-2009, 07:51 AM
http://www.ncttora.com/fsm/1996/SIL/...zfe/terecm.pdf
here is another make sure to compare!!
understand as I look here
I find many termecm se;ections and some have to do with the SRS or ABS and they all look different the last one I sent you may be the one you are looking for!!
which system are you trying to wire in or which plug??
Does this last one look more like the one you are looking for it looks more like the 98 model than the other ones did!! so Make sure that you choose the right one or it will not work and will drive you nuts till you get the right one!!
I Highly reccomend looking through the list I just posted and find the one that looks most like yours in your year amd model before you go through about a month of frustration because the pins are different from yours!!!
JUST LOOK ALL OF THEM OVER AND CHOOSE THE BEST MATCH """terecm""" is what you are looking for and it will be in each system that connects to the ecm easily eliminate any systems you do not have and look at the ones you do!!!
Old 11-09-2009, 03:01 PM
cbrwags's Avatar
The first one you sent says 2000 tacoma on the bottom it looks like the right plug??. My ecm is from a 96 4runner acording to toyota it has 4 plugs 4 rows on each plug 34pin 22pin 16pin 28pin I need the 28pin plug I was told that was the body harness I cant seem to find one so I am just going to solder or use single little plugs to the ecu for the 28pin plug I am hopeing the tacoma ecm diagram you sent will be the same as the 4runner. I need to run power to the ecu, grounds and I think the fuel pump also.
Old 11-09-2009, 03:09 PM
cbrwags's Avatar
Mine are on the bottom for a 1996 toyota 4runner automatic.
Attached Thumbnails I need a pinout for the 3.4 ecu 1996 4runner-96ecuconnectors001-1-.jpg
06-01-2021 01:51 PM
toyotamonster
3.4 Swaps
7
04-16-2020 06:02 PM
XtraCab
04-12-2020 05:25 AM
Daneums
08-20-2015 05:36 AM
Yotoder865
07-09-2015 07:51 PM
Quick Reply: I need a pinout for the 3.4 ecu 1996 4runner
