I hear a new “hum” coming from my rig – what could it be?
Old Jun 8, 2004 | 07:34 AM
rimpainter.com's Avatar
Unhappy I hear a new “hum” coming from my rig – what could it be?
Info:
80K miles
Diff fluid changed to Amsoil at 72K miles
Recent mods: Rear Bilstein’s, auxiliary body mounts welded on.
No leaks.
I tested the “hum” by coasting on the freeway. Yes, I can hear it in and out of gear - its coming from the rear. It happens in gear usually around 2500 – 3500 RPM.
Kind of a bummer because we are heading out Wednesday night on camping trip to the North Rim of the GC.
My thoughts: Wheel bearing going out, new sounds being heard now that the auxiliary body mounts are finally welded on, rear diff, drive shaft…
Your thoughts/ideas?
Old Jun 8, 2004 | 07:48 AM
SLC Punk's Avatar
My guess is a wheel bearing.
Jack up the front end and see if you have any play.
Old Jun 8, 2004 | 08:13 AM
Rick F.'s Avatar
From: Far western Kentucky (transplanted from central PA)
If you noticed the hum after your recent mods, I would choose the aux. body mounts (whatever they are) as a likely candidate. Perhaps you're picking up some added resonance.
Otherwise, I would suggest teaching your rig the words...
Old Jun 8, 2004 | 08:24 AM
Hopefully it's not the amplified resonance of a wheel bearing that has been bad!
Rick- The aux body mounts come with the RB Body Lift. For some reason Toyota did not put the same amount of mounts that the 97+ have.
Regardless, I guess it is a good excuse to use my new Hi-lift and check the wheel bearings on each side. I hope I am ok for a long trip.
Old Jun 8, 2004 | 09:10 AM
hillbilly's Avatar
My bet would be a bearing as well. The only other thought is maybe you have a brake shoe partially hung up. Slightly press on the brake pedal while rolling down the driveway and see if the noise continues. Or cycle the E-brake a time or two and see if the noise goes away.
Old Jun 8, 2004 | 09:15 AM
weezy's Avatar
I have a whistle when I accelerate, but it doesn't bother me, should it?
Old Jun 8, 2004 | 09:20 AM
Threadjacker!
Old Jun 8, 2004 | 09:33 AM
PirateFins's Avatar
only if it's whistling TAPS!!!
icentropy
Sep 16, 2020 02:47 PM
calderp
Engine Swaps
Aug 16, 2016 05:15 PM
calderp
Jul 27, 2015 09:58 AM
keithporter83
Jul 18, 2015 12:37 PM
Sandman
Jul 14, 2015 12:36 PM
