I found a used E-locker!
Old Jul 27, 2004 | 07:30 AM
p1michaud's Avatar
Talking I found a used E-locker!
This past weekend I was fortunate enough to find a used E-Locker from a 1996 4-Runner Limited. The housing is bent because the vehicle was in an accident. I believe the gear ratio is a 4.3 but my truck has 4.1 gears. I have a 1999 3.4L Tacoma. I did also get an ECU and RR Diff Lock switch. I have access to a welder and other tools. I have seen a few posts on retrofitting an E-locker into a non-locker housing. How hard/easy is this project going to be? Can it be done? If anyone is willing to share their experience with this type of retrofit, that would be greatly appreciated as well. I think I figured out most of the wiring Last night. I was just wondering if the “Speed sensor” and 4WD connections on the ECU have to be made in order for it to control properly?
Thanks!
Old Jul 27, 2004 | 09:54 AM
eric-the-red's Avatar
Never done it but here is one write up for the install, if you search there is probably others. If the gear ratios are different from yours you'll have to regear the locker or change the front diff to match the new rear.
http://molmed.umassmed.edu/~kdb/locker/locker.html
Old Jul 27, 2004 | 10:16 AM
toy283's Avatar
Be aware that all the writeups I've seen for the swap involve swapping the elocker into an 8" diff housing. Your Tacoma does not have an 8" housing, it has the 8.4". While not impossible by any means, the location of studs will likely all need to be redone, not just a couple like the 8".
Old Jul 27, 2004 | 10:30 AM
chuckd's Avatar
I've seen a few elockers on ebay lately. I think the last one went for $405, with some of the wiring as well.
Old Jul 27, 2004 | 10:49 AM
rimpainter.com's Avatar
I just bought an entire 4Runner with an e-locker, swapped the front and rear axles with mine, then sold the 4Runner for $300 more than I bought it for.
The front diff swap is the worst - especially without a BL
Old Jul 27, 2004 | 06:00 PM
p1michaud's Avatar
I took everything out this evening
Thanks for your replies guys. A friend and I spent the evening tearing everying off the old 4Runner housing and we removed the e-locker. By the looks of things, the housing is fine. I'm debating wether to cut all the brackets off then rebuild it for the Taco??? Some of the guys on 4x4wire said that I could use an 8" housing from a 1979-1995 Toy truck. Will the 4Runner axles fit that housing? The Runner has ABS but my truck does not.
Old Jul 28, 2004 | 05:05 AM
It would be more of a problem if it was the other way around. I guess you could just leave the ABS sensors in the axle housing and cut the wires.
I would definitely stay with the original housing if it is good. But, how can you be sure? I guess that is the big question. I would like to know too.
(I dont think its the housing that could be the problem per se, I think it would be whether or not something related to the diff was bent)
Can you post some pics of the housing?
Old Jul 28, 2004 | 01:47 PM
toy283's Avatar
You can but I wouldn't. The '79-'85 rear axles are only ~55" wide, the '86-'95's are ~58" wide, and your Tacoma rear is ~60" wide. While the locker will fit into the earlier axles, this is generally for use in earlier trucks. You'd be losing a lot of width, especially with the '79-'85 axle.
Old Jul 29, 2004 | 04:59 AM
p1michaud's Avatar
Pics coming soon...
I took the digital camera and took some pics yesterday evening. I'll post them tonight.
I have decided to build the wiring harness/control unit for the e-locker since I have all the parts in a box readily available. I've been reading and trying to understand all the wiring for the locker. I think that I have it figured out based on various wiring diagrams that I managed to find on the forums. When I get everything working electrically I'll tackle the mechanical end.
I need to find some 4.10 gears and a used e-locked Tacoma (98-now) housing. Do you guys know if there is such a thing as an non ABS e-locked tacoma housing?
Thanks for all the information guys!
Old Jul 29, 2004 | 05:43 AM
Yes there is. My 98 Tacoma LTD TRD had a locker with no ABS and 4.10's.
Old Jul 29, 2004 | 05:40 PM
p1michaud's Avatar
Pictures of Truck, mods and E-locker
96Runner,
Let's try this. Let me know if it does not work. Thanks,
P
hxxp://invis.free.anonymizer.com/hxxp://thumb5.webshots.com/s/thumb2/3/83/45/168938345pLXFEG_th.jpg
hxxp://invis.free.anonymizer.com/hxxp://thumb5.webshots.com/s/thumb3/3/84/65/168938465TgTnMZ_th.jpg
http://community.webshots.com/user/p1michaud
Old Jul 30, 2004 | 05:01 AM
p1michaud's Avatar
Gears and pics
Hi guys,
You have to sort by Newest, on Community Webshots to see the locker pics.
By the way, does anyone have a lead on some 4.10 gears for my locker. It's from a 1996 4Runner and it came with 4.30.
Thanks,
P
Old Jul 31, 2004 | 06:58 PM
Hi guys,
Thanks,
P
Why do you want to go from 4.30's to 4.10's?
Old Aug 3, 2004 | 03:54 AM
p1michaud's Avatar
Why 4.10?
I want to put the Locker in my 99 Tacoma that has 4.10 in it. The Locker came with 4.30 so I either re-regear the front or the locker. I want to have the rear end completely built with locker and all so that I can just pull my axles, remove the current rear end and replace with the locked one.
Jun 1, 2021 01:51 PM
bighaydn
Aug 4, 2015 07:17 PM
irritech
Jul 27, 2015 05:15 PM
msane99
Jul 17, 2015 10:13 AM
AaronM
Jul 8, 2015 07:15 PM
