hydraulic brake booster and MC question
Old Nov 3, 2009 | 07:07 PM
SWPERIC's Avatar
How often does your brake booster kick on?
specifically for a 2002 4runner limited.
next Q if it is turning on more then it should, could the master cylinder be leaking inside itself?
had my gf help me bleed my brake over 9 months ago and im pretty sure she put the pedal to the floor. now every time i hear the brake booster go off, i cant help but imagine that she busted a seal in the MC. is there any way to check this?
Thank you YT.
Old Nov 4, 2009 | 01:03 PM
SWPERIC's Avatar
bump please
Old Nov 4, 2009 | 01:20 PM
hross14's Avatar
Huh-- you mean the ABS pump. I couldnt tell you but i havent heard of them going bad either. Do the pedals feel fine? Does it stop and the ABS work correctly? If the answers are yes--its probably in your head
Old Nov 4, 2009 | 04:30 PM
eric-the-red's Avatar
In my 01, which is the same as your 02, it goes on often. Almost every time I use the brakes.
Old Nov 4, 2009 | 05:21 PM
SWPERIC's Avatar
thank you both!
fountain
Dec 31, 2015 06:08 AM
CanRunner
Jul 20, 2015 01:29 PM
Johntom240
7
Jul 13, 2015 12:18 AM
87turboPA
Jul 12, 2015 07:49 AM
87turboPA
Jul 9, 2015 05:58 AM
