how to take the dash off?
Old Oct 27, 2005 | 01:19 PM
Ladythump's Avatar
This piece around the stereo and such .....
Old Oct 27, 2005 | 01:34 PM
garrett1478's Avatar
https://www.yotatech.com/%7Ecorey/te...stereo/slc.htm
Old Oct 27, 2005 | 01:38 PM
DavidA's Avatar
HU Removal How-To: (For 2000+ 4WD 4Runner)
1. Pull e-Brake Up
2. Put transmission in N
3. Remove Transfer Case Selector Knob
4. Grab rear-most portion of the transmission trim (where the TCS boot meets the trim). Pull up. Remove the rest of the way. There are 4 clips, 1 on each cornor of that piece.
5. Remove Ash-Tray and Cig Lighter.
6. Grab LowerMost portion of the dash. Pull. Work your way around. When you get to the top, be careful, as there is wiring. Unplug the 4 connectors. Leave the wiring at the bottom. Put the dash piece in the passenger footwell.
7. The HU is 4 screws, which can be removed with a screwdriver. Youre going to need the brackets on the side of your OEM HU to mount the A-Market HU.
Tips on reinstallation:
1. When you reconect the wire harnesses at the top, watch where they go. There are 4 harnesses, but 5 plugs. the Black harness fits into 2 spots, the clock plug, and a dummy. If you plug it into the dummy, your clock wont work. The dummy is the lower one of the two. You dont want to use that.
Old Oct 27, 2005 | 02:12 PM
surf4runner's Avatar
ive been searching about this too. my 4runner has lighted ac/heater controls and the bulb(s) is burnt. is there another level to remove behind it?
Old Oct 27, 2005 | 02:14 PM
Bob_98SR5's Avatar
check the tech section, fellas (and lady)
Old Oct 28, 2005 | 09:27 AM
i did, 47 results and none address the lights for the temp display. i will add do it and then i can post the results. probably easy, just haven't the time to do it.
should post my own ? too
kawazx636
Oct 6, 2021 03:03 PM
TheBFA
Feb 15, 2020 06:55 AM
zombie_barbarossa
Oct 2, 2015 10:54 PM
Jdgarrison
Oct 1, 2015 05:22 PM
toyotasaurus
Sep 24, 2015 03:30 PM
