How to remove crank pully bolt
Old Dec 11, 2004 | 11:09 AM
node's Avatar
My 5VZ is sitting on an engine stand at my house. I need to get the crank pully off so I can have it machined. How can I lock the crank in place so I can break the crank pully bolt loose?
Old Dec 11, 2004 | 11:17 AM
fustercluck's Avatar
usually i try to get that off while it's in the car, using a breaker bar, the frame of the car and then bumping the starter to break it loose. in the event that the motor is already out, i've had to lock the fly wheel to the engine stand and the get after it with an impact wrench. if you use a breaker bar, remember the game is not about torque, it's about impact; so go find a big fornicating hammer
Old Dec 11, 2004 | 12:57 PM
node's Avatar
well, that just it. The motor cant be put into the car untill the crank pully is cut down or replaced by something that has less belt sections. The one on there is too thick. I guess I will have to rig up something to hold the flywheel in place.
Old Dec 11, 2004 | 01:07 PM
Have you tried soaking it in penetrant and using a big impact wrench (air will work better)? Since it's a very quick impact and not sustained torque the motor should in theory turn very little, and eventually the bolt should come loose. I haven't done it for this application, but have used the same trick in similar areas with success.
Old Dec 11, 2004 | 01:43 PM
yeah yule have to lock it up and/or use air. the bolt is going to be in the daggone tight. it'll make you think you broke something when it does come loose......then again, you just might. good luck -fuster-
Amer
3.4 Swaps
19
Jun 5, 2017 10:43 AM
thefishguy77
Jul 30, 2015 10:59 AM
v_man
Jul 23, 2015 04:01 PM
redneck17
Jul 17, 2015 07:44 PM
Snort
Jul 9, 2015 03:58 PM
