How fast can you drive in 4wd
Old Dec 8, 2005 | 07:52 AM
  #41
AK95Taco's Avatar
Originally Posted by chubbydude
I disagree that 4wd does help to stop. Gearing down and using all 4 tires to engine break is useful for all non 4 wheel ABS'ers.
Ok in a few very specific instances (like going down a long grade) 4wd and downshifting will help with braking. Since it self modulates all 4 tires vs. the brakes which always have a little bit of bias. Still when it really matters and you need to panic stop 4wd WILL NOT help you. Just as long as everybody remembers that ...
Originally Posted by AxleIke
as for going and stopping, 4wd will help you go on very icy roads, but you still can't stop your car...for example, if 2wd can't make you go, but 4wd can, and you are on a snowpacked road, and a deer runs out in front of you, no amount of gearing down is going to help you...not only that, but 4wd causes your steering to be a lot worse in the snow than 2wd, which can also have bad results...
Yes exactly except for the part that I bolded, 4wd is MUCH better at steering both in keeping the vehicle under control and regaining control in a slide. Nothing beats having power to steering wheels in a slide, just point the direction you want to go and apply a little throttle.
Old Dec 8, 2005 | 08:02 AM
  #42
AxleIke's Avatar
well, i would agree with you on the sliding part, but not on the helping you steer part....your fronts are much more likely to lose traction having power to them when making a turn, it's happend to me many times.
Old Dec 8, 2005 | 08:05 AM
  #43
AxleIke's Avatar
Originally Posted by 4Crawler
There are three types of front hub/axle combintions.
1. Good old manual locking hubs, turn one way to lock, turn the other way to unlock
2. Automatic hubs: http://www.4x4wire.com/toyota/tech/autohub/ that lock and unlock automatically
3. Automatic Differential Disconnect: http://www.4x4wire.com/toyota/tech/add/ which has drive flanges on the wheel hubs and then a gizmo on one side to automatically disconnect and reconnect that half shaft to the differential.
Okay after reading that then i realize we are talking about different things, and there are actually 4 different kinds, becasue these drive flange things are essentially permanent hubs, but don't have ADD so the whole mess turns all the time...thanks for clearing it up, and sorry i didn't research that further before posting
Old Dec 8, 2005 | 09:31 AM
  #44
FCRunner's Avatar
Originally Posted by CoedNaked
My understanding is the front drive shaft is not designed for use over 50 MPH.
Also, changing lanes through slush at 70 MPH? 4wd will have no affect on your control when changing lanes through slush at 70 MPH.
Why the hell would you need to use 4wd over 50 MPH, let alone 30 MPH?
Rediculous.
I tell my wife, if in doubt, use 4wd on the highway even if only patchy ice - I would rather replace parts than loose her! (I have driven 5 toys like this for over 20 years and have not had one problem 60+ in 4WD). Also, half axles are only $140 ea for first gens - rollovers/medical bills cost much more.
bigjstang
Jun 2, 2025 03:56 PM
mskalmus
May 28, 2017 07:51 AM
adammtb
Jul 27, 2015 11:57 AM
TokyoD23
Jul 12, 2015 06:01 AM
Poncho0206
Jul 10, 2015 06:21 PM
