How do I set advance Timing ?
My 90 4runner 4WD acceleration is slow after the mechnic set back to factory Timing specs. It was 5 degree advanced before he do timing check. How can I set it like before ? I am new to this group, hoping to learn something from your guys on car repair.
the way i had to do it on my mustang was to loosen the nut that held the distributor and turn it either clockwise or counterclockwise to get the timing that i wanted. but i bet the runner is TOTALLY different............
Chris
Hrmm...maybe they are all done the same way then..... :confused:
Chris
Linux geek!
Linux geek!
Chris
Originally posted by mtnbkr
Not so much these days. I used to use it quite a bit, but MS made a lot of improvements in Win2K, and I wanted a windows box for some of the toys I use (3G wireless internet). I just got my grubby paws on a P133 that I may install Linux on for ˟˟˟˟s and giggles.
Chris
Chris
Ah i see, I see. I threw it on a little AMD 200mhz box, seemed to preform quit well being a firewall. No hiccups yet
Yeah MS has made a vast improvement over the old NT days. Glad those are over for me!!! Well actually I only have ONE NT box which is for running cisco pix firewall management software, it does "ok"
On my Honda XR 650 L the spark timing is controlled by a pulse generator that I think is triggered by a magnet in the camshaft so there is no way to advance the timing. On my roomates Cherokee its controlled by a flywheel position sensor and also can't be advanced or retarted (well it IS retarted to start with but in a different way). As far as I can tell the Toyotas have a normal distributer so adjustment is something like the way it is on most other vehicles. Hopefully someone will be able to give a diffinitive answer.
Hopefully he timed it correct. Don't know the specifics of yours, but on my son's 85 you have to put a jumper in to set the base timing. This disables the electronic timing control and allows a true base timing setting. If it is not jumpered, it will show advanced, so retarding from this unjumpered timing will retard the base timeing below specs (= gutless)
Chris
Co-Founder/Administrator
I have the specs here, as well as a shot of the box you need to short to time it:
http://www.pnw4runners.net/tech/tune-up_info.jpg
http://www.pnw4runners.net/tech/timing_short.jpg
Mine runs best at stock timing. It was advanced 2 degrees for awhile without me knowing, and it would ping on the freeway under acceleartion, and hills.
Now I get no ping, and the performance seems better at stock timing too.
Re: How do I set advance Timing ?
