How to disable power antenna
Old Dec 2, 2004 | 05:55 PM
User 051420's Avatar
Whoops..me wrong....
Old Dec 2, 2004 | 07:54 PM
Duffdog's Avatar
no its easy guys... just take out factory radio --- clip off the pink/blue and black/pink wires and your done! those are the motor activation wires, no motor activation, no whirring!!!
T
Old Dec 2, 2004 | 09:33 PM
Ishinc's Avatar
duffdog, this is for a 3rd gen right? are you talking about the wires off the harness? not the wires that plug into my aftermarket deck...?
Old Jan 2, 2005 | 11:42 AM
Ishinc's Avatar
hey everyone, just in case you are wondering...I finally unpluged my antenna. I concluded that you can't just unplug the relay to the antenna. You DON'T have to remove the flares to get to the antenna plug. If you have running boards, remove the endcap to the board, its 2 screws underneath and one bolt in the wheel well, slide off. Then remove 2-3 bolts that hold the plastic well closest to the antenna. The trick is to go under the trunk, and pull the black plastic well back alittle from the engine side, not the flare side. The plug will be right there. =)
Kinda of hard to explain, let me know if you need more!
Old Jan 20, 2007 | 10:24 AM
  #25
Josh C's Avatar
Ishinc or anyone can you explain this in a little more detail? The trunk part has me confused...
Thanks
Old Jan 20, 2007 | 12:12 PM
  #26
kevin444's Avatar
cant you just not connect and or cut the attenna lead turn on line i think its going to the headunit.
Old Jan 20, 2007 | 12:52 PM
  #27
Godzilla's Avatar
well what i did on my 2nd gen and just recently on my 3rd gen is just do an inline switch at the antenna motor.. as mentioned just remove a few clips of the liner and pull it back, it actually will bend out of the way very easily. next locate the wires going to the antenna and folow it back to a connector plug that is higher up on the fender. unclip this to make the splice easier. determine the power wire and splice in your wires and run to a switch. I chose a deck plate switch that i got from a junk yard for 50 cents and as well ran a wire from interior lights to supply light to the nice orange circle on the switch.
Old Jan 22, 2007 | 03:49 PM
  #28
Josh C's Avatar
There has got to be somebody who has figured out an easy way to remove the push-in style clips. Or a place where I can get replacements.
Thanks
Old Jan 22, 2007 | 03:58 PM
  #29
Godzilla's Avatar
Well there are many varietys of the push in clips, and really any will do as long as they are the same size. which type? the ones with the square back that you have to press to corners? the ones that have an internal part that kind of work like wall anchors? you can get these clips from pretty much any body shop, or auto store for next to nothing
Old Jan 24, 2007 | 11:06 PM
  #30
ETRNL's Avatar
umm yea i cant believe this is a problem.... there is a wire on the back of the stock radio i believe it is blue.. anyhow cut that and and no more up/down antenna ( i would suggest cutting while it is up..) i tried to find a wire diagram online but i couldn't locate one..
Old Jan 29, 2007 | 07:27 AM
  #31
Ringmaster's Avatar
Originally Posted by gapguy
Same method as the 2nd gen. There's a relay below the stereo thats actually marked "Antenna Relay". I think it's white or something. My mast has been broken forever...too lazy to unplug it.
What he said. I did this to mine just last week. pull the trans shift knob, pull the transfer shift knob, pop the plastic cover off the center console.
Just to the left of the ashtray, there is a tan/brown colored box with one phillips screw retaining it. back the screw out, unplug the harness that plugs into it, and lo and behold, no more antennae motor buzzing.
Radio, tape player work fine. Since the O.E.M. cd player has already bit it, it doesn't play.
Reassemble parts previously removed.
Old Jan 30, 2007 | 06:29 AM
  #32
secrtsrvc's Avatar
The dealer has the plastic clips for $10. I had to buy a new flare and wouldn't ya know.....they didn't come with it!!
Old Jul 4, 2007 | 01:49 PM
  #33
roadking8633's Avatar
Talking unplug relay
here's the deal. just unplug the power antenna relay. it affects nothing else. it is the brown box mounted below the stereo. takes maybe two minutes to get to through the center dash face plate. if you have real small hands and are real limber you can reach behind from under drivers sideand unplug the connector. i unplugged it and the antenna stays down and still picks up stations very well. if you wanted to wire in a switch for the antenna to go up or down it would be much easier doing it from that connector. i think it is the yellow wire that triggers the motor but not sure. probably have to look at a wiring diagram. anyway just wanted to point an easier and cleaner way than tearing out your fender well.[[/ATTACH][/ATTACH][/ATTACH]
Attached Thumbnails How to disable power antenna-07-04-07_1424.jpg   How to disable power antenna-07-04-07_1425.jpg
Old Jul 4, 2007 | 01:52 PM
  #34
by the way i have a 2000 4runner but it's probably the same on all 3rd gens
Old Jul 27, 2010 | 05:51 AM
  #35
mike73737's Avatar
Thanks for the info Roadking, made it easy to put my switch in. One thing though, it isn't the yellow wire, it is the blue wire that needs to be cut and hooked up to the switch. Thanks again.
Old Jan 2, 2013 | 09:34 PM
  #36
hrt4me's Avatar
good to know, thanks!
Old Jan 2, 2013 | 09:50 PM
  #37
bob200587's Avatar
Zombie thread!!!! RAAAARW! BRAINS!!!
DeathCougar
Apr 1, 2018 11:29 PM
mussy01
Dec 13, 2016 08:20 PM
theking11863
Mar 19, 2016 09:36 PM
Sidherish
Aug 2, 2015 01:42 PM
TDonkey
Jul 26, 2015 10:14 AM
