Hopefully not a red flag
Old Jul 17, 2013 | 05:34 AM
kana's Avatar
I was looking at a 99 4runner with 180k with the 3.4 motor in it at a dealership last night.
This thing is dry to the bone for everything, no oil leaks, suspension is beautiful, and no knocking from the engine.
But when i turned it over and let it sat there, still nothing wrong. So shut it back off and noticed that on the fan blades there was lines of fresh grease, it want much. It was coming from the clutch fan.
They told me it hasn't been driven for a couple weeks, and i have no idea how long its been sitting there.
But is that normal? And is it a big problem?
Thanks
Old Jul 17, 2013 | 10:04 AM
94 Newbie's Avatar
I'd assume that the fan clutch is bad.
No big deal to take care of, and probably around $ 100.00 for a Toyota replacement.
It could be a big problem if it is not replaced and the truck overheats, so the thing to do would be to use that as a negotiating tool to knock some dollars off the purchase price, or have the dealer fix it before you buy it.
My .02, anyway.
Good Luck !
Britt
Old Jul 17, 2013 | 10:21 AM
kana's Avatar
Could it be a bad o ring or something?
I was able to knock them down from 6999 to 5800. So i don't think i can do more lol, but i will see once i test drive it if it goes away. It wasn't much oil, but i will keep that in mind!
Old Jul 17, 2013 | 11:39 AM
wyoming9's Avatar
Red face
Make up my mind was it grease or oil
Was the oil fresh and clean??
Perhaps if it was oil some got slopped by the yard boy checking or changing the oil.
Hot Oil looks like lots more then is really there
Old Jul 17, 2013 | 11:47 AM
kana's Avatar
It beeline it was grease, the oil was a lighter color, this was a semi dark brown.
Old Jul 18, 2013 | 02:17 AM
kana's Avatar
Guess i lied, i will need a new clutch fan :/
Old Jul 18, 2013 | 11:26 AM
98SR54RUNNER's Avatar
You should check out RockAuto.com for that fan clutch. A few people around here have gotten replacements there and they were made by AISIN, the same OEM manufacturer for Toyota, but were much cheaper than the part straight from the dealer. I have no idea if this still holds true, but you might want to give it a shot.
Here's the link:
http://www.rockauto.com/catalog/rafr...parttype=11548
Old Jul 18, 2013 | 11:41 AM
kana's Avatar
Nice thank you, ill look into it
Kamaloha
Oct 16, 2015 05:13 PM
Obmi
Oct 4, 2015 11:30 AM
voiddweller
Oct 2, 2015 07:47 AM
the_supernerd
Oct 1, 2015 09:20 PM
Odin
Sep 26, 2015 06:56 PM
