Hilux Surf overhead console installed in 3rd Gen
Old Apr 18, 2006 | 09:40 AM
MTL_4runner's Avatar
Originally Posted by midiwall
??? Those first two pics up there _are_ in my rig.
Ok busted, time for more coffee.
Old Apr 18, 2006 | 09:56 AM
calrockx's Avatar
great, now i gotta get one of these
my girlfriend like to point out that HER matrix has the outside temp and my 4runner doesn't....THINK AGAIN TOOTS! (after i get this)
Old Apr 18, 2006 | 09:58 AM
midiwall's Avatar
Here's the telltale sign: (click as usual)
Look close at the white thing through the lower right of the windshield. That's Tuck Zedo, he's a penguin, the official greeter to the homestead.
Old May 16, 2006 | 04:05 PM
User 051420's Avatar
*not to hijack, just me thinking outloud*
Subaru offers a *very* similar unit in their Foresters....Almost looks din-sized...AND it's in *F
http://www.cars101.com/foresterguage1.JPG
Old May 16, 2006 | 04:08 PM
  #25
garrett1478's Avatar
https://www.yotatech.com/forums/showthread.php?t=83908
your link is screwing with my head
Old May 16, 2006 | 04:12 PM
  #26
midiwall's Avatar
OMG! It's a circular reference!
THE END IS NEAR!!! IT'S A BLACK HOLE!!! RUN! RUN! RUN!
(neil, you posted a link back to this thread! )
Old May 16, 2006 | 04:15 PM
  #27
midiwall's Avatar
I found a small pic:
VERY interesting... I'd say that it's definitely sourced from the same mfg.
okay... I have to at least find out what the "spare" switchpad in there controls.
More info...
Old May 16, 2006 | 04:27 PM
  #28
HOJU's Avatar
The Subaru gauge cluster is $105 (halfway down the page) And according to the housing just below it, it is 1 DIN size
Old May 16, 2006 | 04:28 PM
  #29
DOT3's Avatar
If that thing is plastic, you can match your interior with SEM vinyl dye. Very easy and durable.
http://shop.store.yahoo.com/yourauto...re/semdye.html
Old May 25, 2006 | 05:58 PM
  #30
Doh! Took me 9 days to notice.
Old May 25, 2006 | 07:13 PM
  #31
Los's Avatar
Los
so is anyone going to try the suby one?
Old May 26, 2006 | 08:17 PM
  #32
99SR5's Avatar
this mod looks bad a$$ i think im gonna have to do it some day
Old Jun 24, 2006 | 07:51 AM
  #33
theREALjdmSURF's Avatar
Well, I'm back with another unit, if anyone is still interested! It's the same exact set-u that was sold to midiwall, so his write-up should help everyone interested. The auction will be starting tomorrow, so make sure you find it before it finds you OUT OF TIME!!
.... EBAY seller I.D. JDMISME
Old Jun 26, 2006 | 12:02 PM
  #34
surf4runner's Avatar
bidding...
Old Jun 26, 2006 | 05:18 PM
  #35
midiwall's Avatar
For those curious, this is a direct link to the auction:
http://cgi.ebay.com/ebaymotors/ws/eB...m=280001310040
GOOD LUCK ALL!
Hey REAL... None of the pics are showing up in your auction!
Old Jan 4, 2013 | 10:40 AM
  #36
hrt4me's Avatar
The install was PAINFULLY easy. Only about an hour on my truck (3rd gen with a sun roof), which included time to figure stuff out.
You have to cut the opening in the headliner another inch or so, and when you do - you find that the mounting bolt hole in the console lines up PERFECTLY with one used in the stock console. Then, there are two tabs on the front of the console that fit perfectly into holes. Then (and this is the best part) the connector for the sunroof controls is exactly the same (mechanically and electrically) as that on the Surf console!
Two things to point out...
  • The sunroof portion of the Surf console requires a source of constant 12v for the map lights. This is easily obtained from the old 12v connector that was used for the original map lights. In fact, you can do like I did and pop the pin out of the stock connector, do a bit of mashing on it, and it will fit into the open spot on the Surf connector. Voila... Done!
  • The rearview mirror hanger is another "built in" solution between these trucks. On the stock 3rd gens, the mirror is on a metal plate that doubles as the holder for the original map lights. 3 minutes with an angle grinder and you can separate out the "mirror portion" of the plate. That plate will now work as a stand-alone mirror hanger that fits perfectly into the cutout provided on the Surf console.
I still need to hookup the outdoor temp sensor and the speedo line. As it sits, it only knows a lot about the altitude and barometric pressure, and certainly looks cool at night. Once the speedo hookup happens, then the compass will fire up along with the cool "scrolling lights" display.
Kudos to theREALjdmSURF (Don) for a clean deal and all the legwork he did in figuring out the wiring. (Oh, and I stole his nighttime pic of the display)
edit: (5.6.2006)
Including a wiring diagram for those finding this info via a search.
Code:
Console               Target
BLUE/YELLOW           Constant 12V
WHITE/RED             Switch 12v (ignition)
GREEN/ORANGE          Speed sensor (use DIFF LOCK ECU, pin 10, green/orange)
GREEN                 to dash light dimmer _output_
BLUE                  outside temp sensor (either lead)
YELLOW/BLACK          outside temp sensor (either lead)
WHITE/BLACK           ground
edit: (5.16.2006)
A couple of points of interest for those looking to do this mod.
  • The compass has fairly large steps of 22.5*, so you'll get 16 compass points.
  • The compass _is_ magnetic, but it will only update when it detects the vehicle moving (fwd or rev) so you HAVE to hook up the speed sensor.
  • The backlight on the display is sensitive to the headlights in a "weird" way (it's relative to ground, not hot). If you _don't_ hookup the headlight sensor, the backlight will be VERY dim. When you do hook it up, get the output of the dash dimmer and it will dim with your dash lights.
thanks for the good info!
mskalmus
May 28, 2017 07:51 AM
jerusry
Oct 19, 2015 05:28 PM
BeMiceElf
Oct 10, 2015 09:40 PM
93toyoguy
Aug 2, 2015 07:41 PM
terminator
Jul 27, 2015 07:13 PM
