HID kit for second gens?
Old Nov 30, 2003 | 09:50 AM
914runner's Avatar
does anyone make or know of a HID kit for the second gen. 4runnes? i think it would be pretty cool to have HIDs?
Thanks
Old Nov 30, 2003 | 10:49 AM
dbikeman's Avatar
It just depends on what bulb type you have. If you have sealed headlights then im not sure but they make HID kits for most bulb types.
Old Nov 30, 2003 | 12:14 PM
TeamShiftPoint's Avatar
my cousin has hid's that he retrofitted into his 90 4runner. he has the hid's from the lexus LS430
first you need to get sealed beam conversions.
next you need to get a good set of HIDs, H4 type bulb. or you can rebase them very easily.
you will loose your high beam function cause most companies only sell single beam hid systems.
my cousin also made a custom glare dome for the hid bulbs so that the light shines correctly on the road.
philips or hella/osram hid components should only cost you $300 or so if you're getting a used or oem set from a lexus or bmw, etc...
brand new HID kits are harder to get since laws have been passed prohibiting the import or manufacturing of HID stuff in the US, I've still been able to get philips parts since several shipments have been making it through customs.
Old Nov 30, 2003 | 12:17 PM
Cobb's Avatar
if you use a 6054 sealed beam lamp, i would say wait for a while. i know of a guy that is currently developing a DUAL HID kit for the 6045 lamp. meaning, replace the entire thing with a new lamp assembly and you get HID high and low beams. i can keep you guys posted on the status...if i remember to.
Old Nov 30, 2003 | 12:32 PM
Vato Loco's Avatar
Sylvania makes Sealed Beam HID kits, but I'm not sure how much they are.
Old Nov 30, 2003 | 01:27 PM
914runner's Avatar
what if i put in a HID kit from a BMW or something, do they have high and low beams?
Thanks
Old Nov 30, 2003 | 01:42 PM
Thanks
they are usually separate beams, but if you do find a dual beam setup from a bmw you can retrofit it into the 4runner. you need to get the H4 base from a halogen bulb and use that as the base for the hid bulb.
wiring is fairly simple. positive and negative wires.
coreyedwards7611
Jan 16, 2016 06:38 PM
jerusry
Oct 19, 2015 05:28 PM
justdifferentials
Just Differentials
Sep 17, 2015 06:14 PM
anniesball
Jul 29, 2015 11:46 AM
Edionne13
Jul 9, 2015 01:59 PM
