help! will these fit?
okay. i just ordered the 1.5" daystar front coil spacers for a 1999 toyota 4runner to level the front with the rear.
but i just realized i have the tundra/OEM setup in the front.
will the spacers still work with the tundra coils or will i have to buy spacers for tundra coils.
the spacer on the sonoran steel site says its a 1 inch spacer with 1.5" of lift.
and im not going to run the 3/8" spacer along with the other one.
im thinkin the 1.5" of lift will be perfect.
Remember: when it comes to front suspension on our IFS rigs, the lift you'll get is about 1.5 times the height of the spacer. So, your 1.5" Daystars will actually yield around 2.25". That additional lift will be waaaay too much for the front suspension to handle with the Tundra coils, especially with the 3/8" spacer that's already been talked about.
If you don't have that spacer installed, doing so will level things out somewhat. The most I've heard of people doing is two 3/8" topouts and even that's a stretch on CV's. Regardless of which way you go, a diff drop is a must if you haven't done it already. Good luck!
wait a second.
why would the spacers be advertised as lifting it 1" and then actually yield 2.5"?
im going to see how much this actually lifts it and then go from there.
ill probably return the spacer and get another 3/8" topout.
neliconcepts front was pretty even with the 2 topouts and the tundras.
wait a second.
It's bad to the point where your going to get a personal phone call, your phone will be ringing in a minute here.
EDIT:
Ok I remember your order and I remember making and shipping it, but I don't remember your name, so please call me and I will explain what will happen.
480-201-4139
EDIT:
480-201-4139
