Help Troubleshooting 4wd
Old Dec 27, 2004 | 06:16 PM
KonaYota's Avatar
Unhappy Help Troubleshooting 4wd
I need some help troubleshooting a lack of 4WD on my '92 4runner. No front end engagement in either 4high or 4low. Hopefully it will be something simple like a solinoid, fuse, or linkage. I don't yet have a manual for this Toyota, any recommendations?
Aloha,
Old Dec 27, 2004 | 06:24 PM
ianshoots's Avatar
Can't help much....manual hubs? are they engaged? Mostly wanted to welcom to you Yotatech!
Old Dec 27, 2004 | 06:37 PM
4Crawler's Avatar
Aloha,
Likely you have The Automatic Disconnecting Differential system, here is everything you wanted to know about ADD but were afraid to ask:
http://www.off-road.com/toyota/tech/add/index.htm
Old Dec 27, 2004 | 08:15 PM
callmej75's Avatar
mine was doing the same thing...tested everything and the last thing i found was the cause...a little round check valve that wasn't working right that was inline to the intake and was hooked to the fender. most likely not enough vacuum....
kawazx636
Oct 6, 2021 03:03 PM
Chicken12
Oct 14, 2015 03:54 PM
tylermx71
Sep 29, 2015 08:49 PM
Cycles
Sep 29, 2015 06:37 AM
Boomer8404
Sep 24, 2015 01:12 PM
