Help!noise
Old Jul 22, 2003 | 01:04 PM
Eighty7ToyTruck's Avatar
Help!noise
ok, so driving home today i hear a popping noise in the front end...and its definately from the hub/axle assembly, and it seem like the hubs may not be fully disengaged or the axle maybe loose and rattling, so what size is that big nut in there that holds the axle down? im gonna go buy a socket as soon as i find out...thanks all
Old Jul 22, 2003 | 02:40 PM
got it figured out...seems that when you unlock the hub, that the 2 gears or sprags still hit each other..the toyota dealer here has no idea that there is even a gasket that exists for the hubs..anyone have a part number for the cover to body paper gasket? gonna use 2...
EDIT!!! i think these hubs are from a new style, the guy said 96?? maybe they're a little longer or something??
Old Jul 22, 2003 | 06:25 PM
toyota parts dude's Avatar
it sounds like you got the dials and outer parts from a solid axle truck. the gear that goes in to engage the hubs is thicker. if you grind it down about a 1/16 of a inch it should be fine. if it's a solid axle dial the red part you turn to engage is not flush with the black part. ifs ones the red part is totally flush. that will tell you if you got the wrong parts. hope this helps.
Old Jul 22, 2003 | 06:38 PM
the red dial ones i have are my factory IFS ones and are flush, and the grey dial ones i purchased are flush as well...i still might grind it a little, but i need gaskets...anyone??
Old Jul 23, 2003 | 06:50 PM
samaria hubs dial
the gray ones you have are the aisin lockout hub dials from a suzuki samria. they have the thick gear exactly like the 79-85 solid axle trucks. they will bolt rite up to a solid axle truck. isuzu aisin dials have the thin gear like the ifs trucks they will interchange with your 4 runner. i've seen threads with the part numbers for the gaskets not sure wear you will have to look though.
Old Jul 23, 2003 | 06:54 PM
i swapped the gears out this am about 730 and installed it on my lunch break, voila no more noise...thanks for all your help......i musta messed with it for 2 hours before i gave up and put washers between the hub body and cover so i could go to work..
got to work and it hit me, DUMBASS doh...
Old Jul 23, 2003 | 07:17 PM
so you were using the gray ones when it made the niose? it's suprising how that little difference matters so much. theres real tight tolerences in there i guess.
Old Jul 23, 2003 | 07:19 PM
made the noise with both hubs, red and grey, but with the grey when unlocked and the red when locked because the red spring was broken...LOL almost identical noise too..
Old Jul 24, 2003 | 04:44 PM
if the spring that is broken in the red dial is the bid spring that pushes the gear in to engage the hub you can steal it from the one gray suzuki dial you have. the gear thickness is the only difference.
Old Jul 24, 2003 | 05:02 PM
just swapped the gear out onto the grey one and might do the other side tomorrow, the grey looks A Les, bOT better than the red ones, blends in a lot nicer with the grey truck and aluminum wheels...
Old Jul 25, 2003 | 05:34 PM
yes that would look alot better on your truck since it's gray. i put one of the samaria dails on my 82 4x4 so i would not break up a good pair of toyota hubs i mite be able to sell on ebay. they dont make the noise on my ancient truck. glad to hear you got it working
Old Jul 25, 2003 | 06:42 PM
tpd, thanks for all your help...this board is truely a great asset to toyota owners everywhere...thanks to members like you...
zytra
Jan 24, 2019 03:16 PM
Davebarbier
Nov 3, 2015 03:28 PM
zombie_barbarossa
Oct 2, 2015 10:54 PM
JPV
Sep 28, 2015 03:15 PM
