help!! my 4runner lost all power
i have 94 4runner with 83000 miles and about 2 weeks ago, it started to shake every time it was stopped. eventually it started losing power and now the best i can do uphill is about 20 miles an hour. i have changed the oil and filter; spark pligs; and the cap and rotor. we took each plug wire off axs the truck was running and it didnt make a difference when the wire was unplugged for the 1st and 6th cylinder. so we took off the valve cover on the right bank to see if the valve were tight and we measured the shims on each valve and they were all correct. my friends are mechanics at toyota dealership and they never seen anything like this. today i am going to change the wires but we are thinking that it could be the injectors and we are going to lookinto that next. also it is not blowing any smoke so we are ruling out that the head gasket is blown.
any suggestions or comments would be appreciated
You should still check the ecm for stored codes. It sounds like it's running super rich or it's possibly not burning fuel because there is no spark. Check for spark on ALL the plug wires. If you have access to a shop manual, check out the procedure for testing the AFM and Throtle Body TPS.
Dr. Z
Dr. Z
my friend is going to look up the history at the dealership and i will post any new info i find out but i have had for ayear and a half and its been running mint until about 2 weeks ago
The symptoms you are describing are almost exactly like the problem I experienced when the AFM and TB went out on my 87 Supra Turbo, which is why I'm suspecting those two items on your truck... You have a similar ECM style (OBD I) in your truck also.
Good luck.
Dr. Z
Good luck.
Dr. Z
we changed the spark plug wires and replaced some injectors and power has been restored! only issues left are a hard start and high idle but that will be adjusted by the end of the week.
to all that posted, your suggestions were greatly appreciated
thanks
slutbag
thanks
slutbag
i am pretty sure it was the injectors because they were pretty clogged. its runnning better than it has ever while i have owned it, way more responsive. the spark plugs and everything else was just icing on the cake.
Jun 1, 2021 01:51 PM
jerusry
Oct 19, 2015 05:28 PM
jon.r
Jul 11, 2015 03:34 PM
skoti89
Jul 8, 2015 12:05 AM
Suprarossa
Jul 6, 2015 05:21 AM
