HELP : More about my top speed problem
Old Oct 22, 2004 | 10:56 AM
Mikronized's Avatar
Unhappy HELP : More about my top speed problem
ok..so I'm still having odd top speed issues.. and so after pulling the EFI fuse yesterday it still has the same symptoms...
ECT : off
O/D : on
89 octain
even on flat roads I get up to 69-75 but I can't hold it.. the overdrive kicks in and lowers my RPMs to ~2800 and then I loose speed... I can gun it and the tranny kicks down and my RPMs go to about 4000, I gain speed again... but once I back off the gas a bit, the RPMs go back down and I loose speed. it seems like the speed it likes to be at without downshifting is ~64.. I don't have the egg smell so I don't think the cat is bad...
anybody have any ideas? please?
Old Oct 22, 2004 | 12:52 PM
nfenwick's Avatar
Have the rear brakes been changed or adjusted recently?
Old Oct 22, 2004 | 01:33 PM
Mikronized's Avatar
nope, why?
Old Oct 22, 2004 | 02:03 PM
Del's Avatar
Del
Shouldn't the ECT be "on" and the overdrive "off"?
Old Oct 22, 2004 | 02:16 PM
Brett636's Avatar
Do you have a mechanical fan? If so check your fan clutch, could be frozen.
Old Oct 22, 2004 | 02:19 PM
Mikronized's Avatar
the shop guys just repacked the fan clutch like a 2 months ago so I hope it's not that..
Old Oct 22, 2004 | 02:28 PM
AgRunner06's Avatar
Do a tune-up:
Plugs
Wires
Rotor
Cap
Fuel Filter
Air Filter
Redline S1 Fuel system cleaner
Check your timing - if it's too retarded (haha) you will definitely be losing power.
Do that stuff first then get back to us.
:bounce2:
Old Oct 22, 2004 | 02:36 PM
Flamedx4's Avatar
Sounds like the problem is that once you get to that speed your throttle position is at the 'kick-down' point - it thinks you want to go faster (you do!) and you don't have the "oomph" to do it without a lower gear. Same way a Vette with a six speed can attain it's top speed only in 5th, not in 6th - need the rpms for more power. On older vehicles I would think adjusting the kickdown rod is in order... Is your Throttle Position Sensor adjustable? Or do you just need a tune up as AgRunner suggests?
smthwsn357
May 1, 2024 07:28 AM
msane99
Jul 11, 2015 08:08 PM
wilbertd
Jul 6, 2015 07:39 AM
coryc85
Jul 6, 2015 04:07 AM
karbin
Jul 5, 2015 11:37 PM
