Help on lift for 2WD 3rd Gen
Old Jul 20, 2005 | 06:01 AM
ebelen1's Avatar
First, I'm new to trucks and very ignorant when it comes to terminology on the board. I've read a ton on lifts and what I gather is that 2WD and 4WD 4runners have the same suspension. The only difference is that springs made for a 4WD have to compensate for the extra weight in the front.
Now, I would like a little lift and don't really understand all the OME stuff written here and elsewhere. I plan on getting Bilsteins for shocks and since I was doing this would like to replace the springs. My choices from what I've read are:
1. PP 1" lift springs (PP doesn't recommend it due to the front springs are made for a 4WD and would be very stiff. I hope that the Bilsteins would offset this some.) There is a couple of people that have this setup on the board but have not responded to e-mails.
2. Tundra coils up front and OME's in the back. I haven't read of others that have used this setup with Bilsteins. Will it work and how's the ride.
3. OME's all around (springs and shocks).
Any help would be appreciated...
Old Jul 20, 2005 | 06:48 AM
sschaefer3's Avatar
How high do you want to go?
Old Jul 20, 2005 | 06:51 AM
ugadawg95's Avatar
These ought to get you started...FYI mine is a 2wd.
https://www.yotatech.com/forums/f2/ome-lift-installed-driveshaft-vibration-51725/
https://www.yotatech.com/forums/f2/new-suspension-setup-trd-front-lift-3rd-gen-4runner-41848/
Old Jul 20, 2005 | 06:58 AM
sschaefer3's Avatar
What ever happened with your vibration?
Old Jul 20, 2005 | 07:42 AM
ugadawg95's Avatar
had the driveshaft lengthened...shortened...balanced like 3 times...it's still there. it changed everytime the driveline shop changed it...but it NEVER went away. not really sure at this point what it could be...it is more evident on the driver side like right under my feet. I have checked for loose hardware but came up empty...not sure if the angle is my problem, but i have come up empty on how to change that. Thanks for checking though.
Old Jul 20, 2005 | 01:21 PM
ebelen1's Avatar
Not very high, 1-3 inches. No offroading, mainly for looks.
Old Jul 21, 2005 | 03:49 AM
ugadawg95's Avatar
The Tundra/OME will give you between 2.75 and 3 inches.
smthwsn357
May 1, 2024 07:28 AM
Jun 1, 2021 01:51 PM
jerusry
Oct 19, 2015 05:28 PM
93toyoguy
Aug 2, 2015 07:41 PM
colasurdo
Jul 16, 2015 11:32 AM
