Help with installing an XM Radio
Old Oct 12, 2003 | 06:44 PM
pcdoc1958's Avatar
I have a 2003 wiht NAV and bought an Delphi FM Modulator. The question I have is I tryed to get to the antena behing the radio but have no idea how to do it. It appears I have to take half of the dash apart to get to it. Can anyone provide so insight? Anything would be appreciated.
Thanks
Mike
Old Oct 12, 2003 | 07:12 PM
WATRD's Avatar
If it's like the Tacoma, you only need to take about a third of the dash apart
You will need to remove the face plates for the climate control, then the bezel around the climate controls and the radio. Then it's four 12mm bolts and the radio will practically fall out.
Installation is the opposite.
Old Oct 12, 2003 | 07:20 PM
pcdoc1958's Avatar
Thanks
Thanks for the reply that helps, however the next obvious question is how do I get the faceplates off. It was not real obvious and I did not want to force it.
Thanks
Old Oct 12, 2003 | 07:37 PM
WATRD's Avatar
Just remove the knobs, then the faceplate will pop out with a bit of prying. Use a thin blade around the edges until you pop it loose.
jasonty
41
Dec 23, 2018 01:00 PM
Mrhoadley
Aug 4, 2015 06:08 PM
Yota.Jay
Jul 26, 2015 05:50 PM
TDonkey
Jul 26, 2015 10:14 AM
mtb_taco
Jul 15, 2015 08:36 AM
