Help - Engine won't turn over
Old Dec 9, 2003 | 02:38 AM
Runner4's Avatar
Exclamation Help - Engine won't turn over
Got in the truck to go to work and the engine just kept cranking and cranking and would not turn over. It's not the battery, and I don't think its the starter since it sounds like it is trying to crank it just fine. If I try to crank the engine for about 5 seconds, the cranking automatically stops. Anyone know what could be my problem?
Dave
Old Dec 9, 2003 | 02:57 AM
MTL_4runner's Avatar
You need to check for spark and fuel.
Is the EFI fuse blown?
Check that first....its a garanteed no start if it is.
Old Dec 9, 2003 | 05:41 PM
UKMyers's Avatar
What you posted doesnt' make sense. How could you be cranking and cranking but the engine isnt' turning over. If your engine is seized your starter is going to make some horrific noises. I think what you mean is it turns over but will not fire maybe? Please specify.
Old Dec 10, 2003 | 02:56 AM
Runner4's Avatar
Well I guess your right, it turns and turns (cranks) but does not fire. It finally started started yesterday and seems to be starting fine ever since. I don't know what happened. It was very humid and there was alot of condensation on the everything, so I am wondering if there wasn't some moisture in the fuel line, throttle bottle, etc.
Old Dec 10, 2003 | 03:37 AM
data's Avatar
Senior Member
Mine has been having the exact same problem, but then I will let it sit a couple of seconds and it will fire right up. It has done this to me twice in the last 3 months. I'm not really sure what it could be either.....
Old Dec 10, 2003 | 03:45 AM
Runner4's Avatar
I'm beginning to think its a fuel delivery issue. Possibly the fuel pump is starting to go bad.
Old Dec 10, 2003 | 05:32 AM
Purge the valve on the fuel rail and see if anything comes out.
Do you hear the fuel pumpspin for a sec before trying to start it?
Old Dec 10, 2003 | 09:50 AM
Pretacopower's Avatar
I noticed this with my truck too. Someone told me that if you turn the key to "on"(without starting the truck) and let it sit for a minute, is starts up better. Worked for me
steve miller
Oct 10, 2015 01:40 AM
Kalihi,HI
Jul 9, 2015 04:29 PM
God's Bounty Hunter
Jul 8, 2015 12:54 PM
karbin
Jul 5, 2015 11:37 PM
