Help Disable DRL ??
Old Jul 11, 2004 | 06:45 PM
hhog4dc's Avatar
Help Disable DRL ??
I have looked through the search feature and can not find what I'm looking for. Crawled under the dash and what did I find? Not the box that eveybody else has shown in there write up's. Now you have to take in to consideration that my runner is from Canada and I don't know if they have a different wire diagram. I even went so far as to take out the fuse in the engine compartment for the DRL's and they still came on when I started the truck and dropped the e-brake...I also looked behind both the kick panels and the only thing there is 4x4 module and ABS module. Any input would be great Thanks Doug
Old Jul 12, 2004 | 02:20 PM
AZ4ME's Avatar
My 2000 didn't have anything under the dash for DRL. My DRL unit is in the engine bay, right next to the battery, mounted to the fender wall. A little black box with vented slits all over it. I just unplugged that unit and no more DRL. I don't know if it would be the same for your model, but it's another place to look.
Old Jul 12, 2004 | 02:49 PM
arjan's Avatar
Same for my '97. It was ;-) in the same place. My horn for my alarm is mounted there now.
Old Jul 12, 2004 | 04:18 PM
hhog4dc's Avatar
Thanks guys will take a look.
I just hate the way the lights look when I take photos of my truck offroad.
Just take alook at my avatar. You get the Idea.
Old Jul 12, 2004 | 04:48 PM
hhog4dc's Avatar
All I have to say is that Yotatech Rocks!!!!!!!!!!!!!!
Thanks again for the great info, that was the right place to look and it did turn off DRL's. You guys were right on the ball on that one. Thanks. Doug
Old Jul 12, 2004 | 05:09 PM
hhog4dc's Avatar
Just in case someone else wants to know where to look for the little black box here are some pics to help.
Old Jul 12, 2004 | 05:18 PM
Rick F.'s Avatar
From: Far western Kentucky (transplanted from central PA)
I'm curious why Toyota issued TSB #EL011-00, "Daytime Running Light Disabling Procedure" that has you cut wires (remove pin from the connector, actually) if it's as simple as disconnecting the plug at the box...
Old Jul 12, 2004 | 05:29 PM
hhog4dc's Avatar
I don't know if each year model is somewhat different.
I know that my 98 runner was built in Japan and ended up in Canada.
Go figure?
Old Jul 12, 2004 | 06:31 PM
RTdawgs's Avatar
AHH HA! ive wondered what that box was ever since ive been looking for a place to run my ARB compressor! guess what? im going to kill two birds with one stone: bye bye DRL, hello a good ARB compressor mount.
Old Jul 12, 2004 | 07:05 PM
Mad Chemist's Avatar
As an alternative, because I do like driving in the city with DRL's, especially in Seattle when it is rainy/foggy, is wired up the DRL's to a switch in the cab. So, I turn them off when offroading, but leave them on most of the time.
Old Jul 12, 2004 | 09:51 PM
RTdawgs's Avatar
i thought about that David, but wouldnt that be just like using your headlight switch? whats the advantage of having another headlight switch?
Old Jul 12, 2004 | 11:00 PM
arjan's Avatar
It's not really a headlight switch. The lights are controlled by the ignition.
Old Jul 13, 2004 | 03:22 AM
Rick F.'s Avatar
I agree that there are a lot of times I prefer to have the DRL's functional. One situation is in foggy conditions where I have the fog lights on and can lower the headlight output to DRL levels. I don't get as much headlight glare but still have a decent forward "throw". Of course, that's dependent on the particular conditions and the amount of glare I can tolerate. Then there are the times it would be nice to have them off w/o having to turn off the engine and restart after fiddling with the emergency brake... Like at the Drive-in movie or campground.
Old Jul 13, 2004 | 05:41 AM
RTdawgs's Avatar
yes but if you leave your headlight switch on, the lights turn off/on with the ignition, too.
Old Jul 13, 2004 | 05:51 AM
Mine don't, at least on the 98 I could still drain the battery. It's a no-brainer to leave the DRL's on. Boils down to a preference thing I guess, just throwing another option out there.
Old Jul 13, 2004 | 03:03 PM
leebee's Avatar
same spot on a 93?
hey david
just wondering if you would send me a diagram of the switch/wiring set-uo you used. im going to check and see if the black box is in the same spot on my 93. i like your idea of being able to selectively turn the drl's off. thanks in advance.
lee
Old Jul 13, 2004 | 04:04 PM
RTdawgs's Avatar
93s do not have DRLs that im aware of.
Old Jul 13, 2004 | 05:23 PM
leebee's Avatar
canadian requirement
hey ryan
i believe transport canada made drl's mandatory in 91 or shortly thereafter. my 91 corolla had them (i think), my 93 mr2 definately did, my 94 corolla wagon had them and the 93 runner has them also. i found the fuse under the hood for the drl's but no black box. didnt bother pulling the fuse as it doesnt disable them as per a previous post. anyone have any ideas as to where the unit may be hidden?
lee
Old Jul 13, 2004 | 06:21 PM
RTdawgs's Avatar
oh ok lee, i didnt realize you were north of the border.
Old Jul 13, 2004 | 06:57 PM
leebee's Avatar
no worries ryan, i guess i should have ended my sentence with 'eh'! just wish some of the stuff available for you folks was available here. the duty, taxes, shipping etc make it cost prohibitive sometimes to order from south of the 49th. talk with you soon, eh.
lee
