HELP! Dealership says my rear diff might be shot.
Old Dec 24, 2008 | 04:29 AM
rearviewmirror's Avatar
A few days I posted a thread about my rear left brake binding up. Well I get a call last night saying that even with the brake drums removed there is some binding when the axle spins forward, but none spinning backwards, and it only happens to the left wheel. I said there was no way there is a diff problem, the damn thing only had 55k miles on it, it's never been off-road or in an accident.
The symptoms are exactly what you'd expect if you had a locking up brake, you put it in drive and that one wheel holds you in place. The reason I have my doubts is that when I felt it bind up I adjusted the brake shoes all the way leaving me little to know brake pressure but I didn't have any binding issues. The first time they had it they said they bled the system and adjusted the shoes. Then it starting binding again.
Any thoughts? I'm no expert on these 4Runner axles and diffs but it seems illogical they could fail with such low miles.
(2000 4WD w/ 55k miles)
Old Dec 24, 2008 | 05:15 AM
dbcx's Avatar
Sounds like they are just trying to get money. If you slacked of the brakes and it was ok, then they adjusted it and said it was back. I would get it back and check it myself. You are going to have some drag trying to spin it by hand even if it is an open diff.
I would jack it up so both tires are off the ground and see what it does, one tire should spind foward one in reverse see how it feels.
Then pull the drums on both sides and try it see what you get.
A freind of mine took his truck to the dealer and they said he needed a clutch fan and a belt. His fan was fine but it was some fast money if they charged him for a $200 fan clutch just to swap a belt. They were going to charge him $400
Old Dec 24, 2008 | 05:30 AM
mjwalfredo's Avatar
It seems that sometimes the rear adjusters can get "stuck" sometimes, causing the adjuster to keep pushing the shoe closer to the drum without pulling the parking brake. I had this happen to me so I pulled the rear brakes apart. After cleaning and greasing up the bellcranks the problem went away.
I had the same symptoms though, the wheels would spin freely if I adjust the brakes all the way out but if I set the adjustment correctly, they would start binding after a day or two of driving.
I would definitely be skeptical of the dealership's advice on your differential. Take it to someone that specializes in rear ends if you are that worried about it. In my experience, the dealerships and general mechanics a lot of times don't know too much about them.
Old Dec 24, 2008 | 05:32 AM
waskillywabbit's Avatar
Get a professional 2nd opinion some where else. Take it to another mechanic and get a 2nd opinion but don't tell them about the dealership's diagnosis. Then when it turns out they were lying to you at the dealership, take the actual repair ticket back to the dealership service manager and let the arse chewing begin.
Old Dec 24, 2008 | 05:36 AM
I am in doubt myself. I would think if the diff was shot it would be an all or nothing affair. Not working fine one day but not the next. I would also suspect there would be some hellacious noise associated with a failed diff.
The brakes were definitely locked in place when I had it at home one day. Once I backed the shoes in the axle would spin freely.
Old Dec 24, 2008 | 09:51 AM
UPDATE...
They disconnected the drive shaft and the rear axle/diff spun freely. Now they're suspecting an issue with the transmission or the transfer case.
Old Dec 24, 2008 | 10:46 AM
Tofer's Avatar
Sponsor
how is the tranny going to affect ONE tire?!>
Old Dec 24, 2008 | 12:30 PM
dbcx's Avatar
Step away from the dealership........
They can get more $$$$$$ out of the tranny than the rear end
Old Dec 24, 2008 | 01:27 PM
97ltd4x4's Avatar
Yea,something is not adding up...I suspect brake/e-brake problem..possible wheel bearing,but it would have to be really bad to drag...almost sounds like axle seal leak is swealling up that brake shoe,or e-brake is hanging on that side.....
Old Dec 25, 2008 | 06:02 PM
I've got it back home, not sure what to do next, no real diagnosis other than it doesn't have a problem when the drive shaft was disconnected.
Old Dec 25, 2008 | 07:34 PM
BDTB's Avatar
My '93 pickup had a similar issue. It turned out to be the E brake was stuck in the engaged position. It was only the rear passenger side wheel that was binding up. I had to whack the inside of the wheel with a mallot. Problem fixed.
Old Dec 26, 2008 | 06:17 AM
BigBallsMcFalls's Avatar
u r getting boned
disconnecting the driveshaft won't do a damn thing and has
nothing to do with one wheel binding...
[unless the driveshaft slip joint was frozen and pushing into the diff,
which would not be the case. you'd have vibrations and clunking]
Old Dec 27, 2008 | 01:01 PM
Mulkey's Avatar
Why are you taking it to a dealership?? The Yota is out of warranty which means NEVER take it back to the dealership unless you're trading it in. Find a reputable transmission guy.
polo451
13
Nov 20, 2016 07:49 PM
jerusry
Oct 19, 2015 05:28 PM
Daneums
Aug 20, 2015 05:36 AM
jaretstuff
Aug 4, 2015 02:08 PM
scottyg486
Jul 19, 2015 05:34 PM
