HELP: 1st Gen Front end noise
Old Feb 5, 2004 | 06:27 PM
kwando's Avatar
Here is what is happening to my stock 86 4Runner. There is an awfully loud noise that is coming from the front driver side when the truck is moving. It almost sounds like a seized bearing (that is the best way I can explain it). Happens either when I have the front hubs locked or when it’s in 4WD (with or without the hubs locked). It is not consistent and goes away when I accelerate or brake (in 4WD). Once it stops most of the time it returns when I hit a small bump.
With just the hubs locked the noise does not go away, it’s continuous. In 4WD it goes away when I put it in 2WD.
It has never happened in 2WD.
What can be wrong? What additional steps should I take to trouble shoot this?
Any help is appreciated.
Thanks for your time,
Old Feb 5, 2004 | 09:44 PM
Fahrenheit 451's Avatar
Sounds like you might have a bad CV joint, the curse of the IFS.
Old Feb 11, 2004 | 07:03 AM
kwando's Avatar
Are there any sure signs of a bad CV joint just be looking at one?
Jun 1, 2021 01:51 PM
mskalmus
May 28, 2017 07:51 AM
coryc85
Jul 6, 2015 04:07 AM
toyoda8488
Jul 5, 2015 10:18 PM
CJ94yota
Jul 3, 2015 10:14 PM
