Headlight Removal
Old Feb 6, 2005 | 06:43 PM
msw0085's Avatar
Headlight Removal
Hey guys I have just bought a 1996 4Runner Limited 2wd with 90k mi. as my first car. I have no knowledge on these trucks as far as mods go. That said, I bought a pair of HID/Xenon? bulbs that i want to install myslef/ help of dad but we cannot figure out how to remove the headlight assembly. The only thing I can see to remove are the metal clasps on the top and the screw that holds the corner lights in. I'm sure this is a rediculously basic procedure that you all are laughing at, but any help with this would be def. appreciated.
Also, while searching the forums for the answer to this problem, I have noticed several people that have retrofitted the entire xenon assemblys from other cars. Is this required?? Have I wasted money on these bulbs in my ignorance?? haha...thanks alot yall.
Old Feb 6, 2005 | 06:52 PM
jimbo74's Avatar
you dont need to remove the whole assembly... jsut find the wire bundle under the hood, there is a ring that secures the bulb into the light
Old Feb 6, 2005 | 07:03 PM
kevin444's Avatar
Remove the rubber suction thing that is around the wires that lead into the headlight housing. Unhook the spring loaded bulb retainer. Pull out old bulb put in new one and do what i just said in reverse order to install.
Old Feb 6, 2005 | 07:36 PM
msw0085's Avatar
wow that took all of 10 min to do, thanks alot.
Old Feb 6, 2005 | 08:06 PM
Randomness's Avatar
and make sure you didn't touch the glass on the bulbs with your skin...
Old Feb 7, 2005 | 01:11 PM
msw0085's Avatar
Ya i tried not to, and i dont think i did, but what happens if you do...? Do you lose clarity or something with the fingerprints?
Old Feb 7, 2005 | 01:35 PM
kevin444's Avatar
The finger oil might damage the bulb. Possibly blow up?
Old Feb 7, 2005 | 01:52 PM
Randomness's Avatar
Exactly what kevin said...the oil from your fingers will basically make the bulb blow when it gets hot.
Sep 4, 2015 09:27 AM
landes94
Aug 16, 2015 12:20 PM
mldave
Aug 10, 2015 09:23 AM
rushw
Jul 18, 2015 01:46 PM
icentropy
Jul 14, 2015 10:23 AM
