Headlight bulb
Old Dec 11, 2002 | 04:35 PM
Brad's Avatar
Question Headlight bulb
Does anyone know if replacement bulbs for the 92-95 4runners fit all second gen(90-91 too)?
Old Dec 11, 2002 | 04:56 PM
Cebby's Avatar
Open up the wallet
If you are talking about the bulbs themselves, then no. The 90-91 uses a regular sealed beam (I think). The 92-95 are composite lamps and take a 9004 bulb. If you wanted to change the whole lamp assembly, then you'd likely have to change your grille and maybe corner lamps also. The sheet metal underneath that holds everything should be the same (don't quote me). See if you can find a 92-95 and do a visual and take a few measurements. Hope that helped.
4banginRunner
Nov 13, 2015 05:23 AM
mreagen
Oct 5, 2015 04:27 PM
beltcutter
Sep 30, 2015 06:14 AM
Scotttekoch
Sep 28, 2015 10:30 PM
JPV
Sep 28, 2015 03:15 PM
