headlight ?
Old Jan 14, 2005 | 09:59 AM
1987 street toy's Avatar
headlight ?
I read here on yotatech that someone rewired the low beam to stay on when you turn on high beams. I would like to know how to do this. did a search with no luck. my truck is a 87 1ton 2WD 22re 5 speed
Old Jan 14, 2005 | 10:16 AM
bike4miles's Avatar
Actually, I think that post was a call for help becaus it was a mistake that the high beams wouldn't go off. Just get an H4 headlight conversion and install some high end bulbs like Silverstar. They are about 50% brighter than stock.
Old Jan 14, 2005 | 12:18 PM
03TRDBlack's Avatar
I would advise against doing this. You are going to go through a TON of bulbs if you burn both filaments of an H4 at the same time. The excess heat that builds up will cause the filaments to break prematurely. Also, your wiring harness may not be able to handle the extra wattage and may burn up on you as well. Get a set of aux. lights if you need that much extra light. Then you could wire those to come on with your highbeams and have the extra light you need.
Old Jan 14, 2005 | 12:33 PM
4Crawler's Avatar
I run a set of 55/100 watt H4 bulbs in my 4Runner. Gives good light output on low beams, then tons on high beams:
http://www.4crawler.com/4x4/CheapTri...adlights.shtml
A good H4 housing and bulbs, plus an upgraded wiring harness will do wonders for the Toyota headlights. The stock Toyota wiring is pretty marginal to begin with, add 15-20 years of use on the switches and wiring and it does not get any better.
kawazx636
Oct 6, 2021 03:03 PM
4banginRunner
Nov 13, 2015 05:23 AM
mreagen
Oct 5, 2015 04:27 PM
beltcutter
Sep 30, 2015 06:14 AM
JPV
Sep 28, 2015 03:15 PM
