Head Gasket testing methods
Old Jan 22, 2004 | 09:10 AM
freeflyer's Avatar
After taking my 4 Runner to the dealer for a missing problem, he said he needed to do a whole list of things and if that didn't clear it up he would have to change the head gaskets.
My question is: Is there any way to pinpoint a blown head gasket from the start?
Note: No sign of oil in the coolant and no sign of coolant in the oil.
Thanks, Bruce
1995 4 Runner v6 75K miles
Old Jan 22, 2004 | 10:11 AM
p00kienrayray's Avatar
what problem led you to take it to the dealer in the first place?
Old Jan 22, 2004 | 10:19 AM
Doc279's Avatar
I would think that a compression check would show the blown head gasket. A gasket blown between two cylinders would make both cyclinders down on comperession ( weak )
It is possible to blow a head gasket and yet keep the oil and water where it should be.
Just my two cents worth !
Old Jan 22, 2004 | 10:28 AM
is it overheating or something?
Old Jan 22, 2004 | 02:42 PM
SLC Punk's Avatar
Yep compression test should show a leak between two cylinders.
Old Jan 22, 2004 | 02:47 PM
MTL_4runner's Avatar
1) compression test
2) check for signs of oil in coolant and vice versa
Old Jan 22, 2004 | 03:23 PM
its2slo's Avatar
the compression test could give you false hope, i would just have a leakdown test done.
Old Jan 22, 2004 | 06:39 PM
lunatic14r's Avatar
There is a very neat tool sold a most car part stores it is a dye that you put in a in the tool ( looks almost like a turkey baster ) ant with they radiator cap off you pull the hot gases out of the radiator into the tool (not coolant) and if the dye changes color you have a blown head gasket or cracked head. what changes the dyes color is when you have combustion gas in the coolant and thats not good
Old Jan 23, 2004 | 07:42 AM
freeflyer's Avatar
Thanks, guys.
kgcwb44
Jan 29, 2023 10:02 AM
the1998sr5
15
Jul 14, 2020 08:35 PM
Colington
Mar 8, 2020 09:51 AM
Sep 4, 2015 09:27 AM
Coreyr384
Jul 10, 2015 11:13 AM
