Having a tough time removing running boards
Old Sep 18, 2003 | 04:30 PM
Brad's Avatar
Hey Dudes-
I can't seem to get my stock running boards off after wd-40 and some other rust polymer desolver. I yanked, cussed and yanked some more and the bolts won't move. Should I have the nuts and bolts cut off, should I try warming things up with a torch. What shall I do. I have sliders that need to be put on. HELP!!
Old Sep 18, 2003 | 05:16 PM
fooddude's Avatar
if you have an air compressor bust out an air ratchet. If not find someone with one it will get any bolt off.
Old Sep 18, 2003 | 05:52 PM
midiwall's Avatar
You can also try to add a length of pipe over the handle of your ratchet. That'll give you more leverage on the bolt.
Is it just one bolt, or all of them?
Old Sep 18, 2003 | 06:04 PM
Yoter's Avatar
Guest
I miss mine now. Every day my left ankle & right hip hurts from climbing up in my Runner. I need to get some tube steps. :cry:
Old Sep 18, 2003 | 08:24 PM
DrumheadAR's Avatar
Took my steps off of my '91 runner before i traded it. I ended up having to put the pipe over the ratched, AND using a hammer. Took about 2 hours to do the 15 minute job. You COULD just go to the nearest creek bed and try ripping them off on a nice sharp rock.
Old Sep 19, 2003 | 03:53 AM
waskillywabbit's Avatar
Air power
Air power is the only way to go. You either fix the problem or rip it off and fix the problem!
Brian
Old Sep 19, 2003 | 03:55 AM
SLC Punk's Avatar
Have you tried PB blaster?
That is the only thing that I can get to work. WD-40 and Liquid wrench just don't work for me.
Try PB, spray a crap load of it on the bolts, and let it sit for a couple of hours..
Old Sep 19, 2003 | 04:00 AM
jacksonpt's Avatar
Senior Member
I agree with most of the above comments...
1) try PB-Blaster (far superior to WD-40) and a breaker bar.
2) find some air tools
matrad
Aug 26, 2024 08:21 AM
Team420
Jan 12, 2021 04:57 PM
crazypaint
Jun 23, 2015 03:27 AM
95Runner
7
Jun 8, 2002 01:02 AM
