Harmonic balancer: is any amount of wobble OK?
Old Jan 8, 2016 | 03:52 PM
MudHippy's Avatar
I'd love to hear what they have to say about that!
Not really though. Since I can already imagine what kind of dumbass BS excuse that would be. If I were you I wouldn't even bother asking. You've suffered enough of their stupidity already.
BTW, it needs replaced ASAP. Running it like that is no bueno.
Old Jan 8, 2016 | 03:55 PM
vasinvictor's Avatar
Why would that ever cause problems? Seriously asking.
Old Jan 8, 2016 | 05:01 PM
MudHippy's Avatar
Harmonic balancers are "balanced" from the factory. It would now be out of balance. And will cause vibration while spinning. Like any imbalanced rotating mass would.
See the holes drilled to remove weight for balancing? They're there for a reason.
The purpose of a HB is to help remove vibrations from the crankshaft. Not impart vibrations to it.
Old Jan 8, 2016 | 05:31 PM
Bass Player's Avatar
I'm demanding a new part, whether it's a problem or not. That's just inexcusable.
Old Jan 8, 2016 | 06:15 PM
  #25
piglett's Avatar
correct
why would they even put such a part on in the 1st place?
I would never put a broken part on a boat engine
maybe truck are different?
Old Jan 9, 2016 | 06:30 PM
  #26
aowRS's Avatar
They probably damaged it when the 'mechanic' grabbed his trusty chain whip to hold the pulley instead of retaining it correctly while torquing the crank bolt.
Andreas
Old Jan 11, 2016 | 06:19 AM
  #27
The shop owner called this morning to tell me he has a new harmonic balancer ordered, so I'm hoping for a happy ending.
Old Jan 15, 2016 | 06:21 AM
  #28
Well, they did good with the replacement HB, as far as I can tell. I had taped the page out of the service manual on the steering wheel with the torque spec highlighted. Hopefully I'm good for another 100K miles.
Old Jan 15, 2016 | 06:44 AM
  #29
aowRS's Avatar
Glad to hear they took care of the issue.
As for the timing belt mileage, I had mine replaced for the first time at 170,000 miles. I'm now at 346,000 miles and will replace it (and everything) again soon. Whenever the mood strikes me.
Andreas
Old Jan 15, 2016 | 06:03 PM
  #30
rworegon's Avatar
Glad they got you taken care of.
justdifferentials
Just Differentials
May 5, 2016 07:01 PM
Zealous84milo
Dec 15, 2015 03:08 PM
ward
Dec 10, 2015 10:35 AM
punks_is_4x4
Dec 9, 2015 06:31 PM
4rollin
Dec 5, 2015 07:17 PM
