Got back from dealer sqeeky belt noise solution here
Old Apr 30, 2003 | 01:04 PM
impulsebrklyn's Avatar
well i went to the dealer and i saw my neighbor he is the service manager and as soon as i described the noise he knew what i was talking about. There seems to be a bolt that holds the pully, and when it is cold the bolt is just alittle to small and the pulley slips. So when it heats up it becomes the correct size and stops. He said they will have the new bolts in around 3 weeks from toyots to fix the problem. He said before they figured this out they were replacing the belts and found it was only a temporary fix.
Chris
Old Apr 30, 2003 | 02:47 PM
jharris2's Avatar
Chris -
If you can, please mention this to your neighbor -- mine squeaks after it warms up! Basically, it's usually quiet when I start out, then a bumping noise, then a squeak.
On a recent trip to Dallas, after I had drivien 15 miles or so, it was of high enough pitch that I could hear it over the stereo. Downright annoying!
Thanks!
Old Apr 30, 2003 | 04:32 PM
that needs to go to the dealer, there is something more then just what im talking about wrong
what is the license plate mod????????
Old May 24, 2003 | 06:46 PM
SRGNTD
Guest
Posts: n/a
Same problem here. Belt squeak/chirp
Hey Chris,
Did you ever get that pulley bolt put in and did it resolve the squeak problem?
I have the exact same issue here in the morning, so they replaced the belt and sure enough 2 weeks later it's squeaking again intil it warms up.
BTW does your A/C compressor "chirp" when it engages every 30 seconds or so when the A/C is on? Could that be related to the bolt as well?
mskalmus
May 28, 2017 07:51 AM
MTLroadierunner
Jul 15, 2015 12:58 PM
Gamble_STi
Jul 7, 2015 07:54 PM
MTLroadierunner
Jul 6, 2015 12:17 PM
elwood73
Jul 5, 2015 07:07 AM
