Good Buy?
The verdict is in from teh Toyota specialists...
Timing chain has maybe 5k miles left on it
water pump is gone
tie rod ends need replacing
new clutch hose
Rear main seal
Sway bar links replaced
and some more but why list them cause this thing needs an easy $2k to bring it back mechanically...
They said it hasn't seen much service at all. Still has OEM plug cables!! which is impressive i guess.. but hell... This thing has never seen a tune up other than fluids.
Well the idea was fun while it lasted...
Back to the drawing board
-Jason
water pump is gone
new clutch hose
Rear main seal
-Jason
For 240,000 miles - that list almost seems to be normal maintenance. Also, if it is a 3.4 - it has a timing belt, not a chain. Not that it matters, the belt would be at the end of its useful lifespan. And considering the water pump is gone - good thing to replace. Still sounds like a good deal to me though.
belt... chain... you know what i meant
So, to keep you all up to date on my 4runner search, I pulled the trigger on a '99 this Monday... FOLLOW THIS LINK
-Jason
-Jason
nanhodges2733
May 29, 2020 03:28 PM
crashburnoveride
Jul 10, 2015 06:39 AM
