Fuel Pump - 1GR-FE 4.0L V6 - what's the psi rating??
Old Oct 14, 2005 | 10:55 PM
windancer4x4's Avatar
Hi.. I wish to know the psi rating of the fuel pump in the 2003 1GR-FE 4.0L V6 ..The one I got in the fuel tank is from a 1992 3.0 L V6 (3VZ-E) which is rated at 38-44 psi @ no vacuum. Will it work fine on road, off-road, free-way speeds & when 4wheeling?
Thanks
p.s.: surely some of you will notice that this is related to the swap I'm doing having a 1GR-FE engine planted in my 1992 truck (replacing the old 3VZ-E 3.0L)... wish me luck..
__________________
Fakri of NMSU... Red, White & Blue
No [TOYOTA] Problem can withstand the assault of sustained thinking" -Voltaire
Old Aug 14, 2006 | 11:57 PM
So, I ended up modifying the fuel tank in my truck where I fited the fuel pump from the 2003 Prado that came originally with the dono truck! Fabrication, cutting and welding involved with great care to ensure leak-free durable instalation.....
kawazx636
Oct 6, 2021 03:03 PM
mussy01
Dec 13, 2016 08:20 PM
TACOJO
Nov 27, 2015 05:26 PM
digdug40
Aug 28, 2015 02:24 PM
