fuel injector questions and more
Old Dec 11, 2003 | 06:39 AM
okidoc's Avatar
How do you tell if there is a leak in the injector to manifold seal/o-ring? IF I'm thinking correctly it would be the same as a manifold leak and would show up w/ a vacuum gauge right? My vacuum gauge is steady and at the correct level (20-24 can't quite remember)
I am experiencing fuel smells while driving but can't find a leak I have not experienced a drop in mpg so I think it's something small, but needs fixing.
Also how do you test the emission cannister? I have vacuum to the can but do not have vacuum coming out, I was not aware of any servos or anything involved w/ testing it. I would to make sure that it is bad before dropping $140 on it. I thinkthis is prolly the source of the smell.
95 3.0 SR5
Old Dec 11, 2003 | 01:57 PM
okidoc's Avatar
BTT
any help on the gas smell would be great.
Old Dec 11, 2003 | 02:05 PM
MTL_4runner's Avatar
Sounds more like an evap canister prob.
Tough to say for sure though.
Old Dec 11, 2003 | 03:08 PM
My99's Avatar
If you're smelling gas, just follow your lines under the vehicle from the tank to the injectors. That's all you can do. If you can't find a leak, then I wouldn't worry too much about it unless it's so bad you're passing out. If you can smell it, you should be able to find a leak somewhere.
Doug4320
Mar 24, 2018 10:11 PM
raptor510
Feb 17, 2017 07:11 AM
pyramid
Jul 30, 2015 10:05 AM
TURBOrunnerNM
Jul 22, 2015 11:01 AM
karbin
Jul 5, 2015 11:37 PM
