Fuel Injection Problems
Old May 7, 2004 | 10:22 AM
Cooper04's Avatar
I was wondering if anyone on here knows some good ways to impove fuel injection on a 96 Toyota 4ruuner. I'm looking for better performance. I know for a fact that the fuel injectors have never been cleaned professionally, and the filters or pumps haven't been replaced. What would anyone with knowledge in this area of mechanic recommend.
Old May 7, 2004 | 11:31 AM
HaveBlue's Avatar
What are you trying to achieve?
If you're looking for better performance, try the deckplate mod and larger exhaust. You will notice a very marginal increase in performance. You won't gain much from the injectors, especially if they have been cleaned.
If you are looking for a big bump in power, install a supercharger. Then you can add larger injectors and a few other things that will really give the beast some kick.
Old May 9, 2004 | 09:32 AM
Nic's Avatar
Nic
For starters, you may want to first run a can of BG 44K through it. After you get done with that, you may want to change the fuel filter since the BG 44K may put a lot of deposits in it. Also wait to change your oil after doing the first two. I noticed my oil got dirty afterwards, especially on my Camry.
I found out about the BG 44k here. I am convinced it is good stuff. It really helped my 84 Camry run better.
At the very least, change your fuel filter. When I changed the one in my Tacoma, it was really dirty.
Also, I forgot to add, a throttle body cleaning may help too.
You should be able to do all this yourself if you have the tools and patience.
Old May 9, 2004 | 09:44 AM
calamaridog's Avatar
Buy new fuel filter, plugs, and two cans of Seafoam Motor Treatment. Change the fuel filter. Read the directions on the Seafoam can. You want to run it through the fuel system, directly into a vaccum line. Seafoam will clean your injectors and remove carbon build-up. Change plugs. Motor should run much smoother and powerful, like new.
Old May 9, 2004 | 10:56 AM
MTL_4runner's Avatar
How does the seafoam clean the injectors if you run it all through the vacum lines?
That may clean the valves but how does it do the injectors?
Old May 9, 2004 | 11:43 AM
You are right. I was in a hurry and I did not explain myself completely. Run a can (16 oz.) with a full tank of gas to help clean the injectors. Run it through a direct manifold vaccum line (p.v.c. valve or brake booster) to clean carbon build up. Results = smoother idle, more pick-up, etc. This stuff really works great and I recommend it all the time.
www.seafoamsales.com
And no, I don't work for them
jbv808
Aug 6, 2021 04:47 PM
Sleaker
Aug 26, 2020 06:03 AM
Eggslinger
Jun 8, 2019 03:32 PM
gary4runner
Sep 24, 2015 12:53 AM
shisha1999
Jul 13, 2015 11:09 PM
